Introduction
If the coin cell or CMOS battery of your Lenovo ThinkPad T480 begins to fail, follow this guide to replace it.
The CMOS or coin cell battery provides power to the CMOS (complementary metal oxide semiconductor) chip. Some signs of CMOS battery failure include: settings in the computer setup changing, the clock resetting, “Booting Error” messages, the laptop running slowly, or the laptop shutting down.
Prior to beginning this repair, be sure to disable the internal battery, shut down the laptop, and disconnect from the external power source.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
3 Guide Comments
good documentation easy to follow top woman
Should you then scrap old adhesive and replace with new adhesive pad, sticking a new battery to it?
@bonny60873 Hi Bonny, if you can reuse the existing adhesive, that should be okay. Sometimes the adhesive gets damaged or becomes less sticky when you remove it from the old battery. If that happens, you may want to apply a new piece of double-sided tape. For tips on applying double-sided tape, our How to Use a Pre-Cut Adhesive Sheet guide provides helpful information, even if you’re not using a pre-cut sheet.
