Lenovo ThinkPad T470 SSD Assembly Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
123
All Time:
2,860
Comments: 6
6 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the SSD assembly in your Lenovo ThinkPad T470. The SSD assembly includes a plastic bracket, a metal enclosure, the SSD itself, and the SSD connector board. If you need to replace any of these individual components, follow the Lenovo ThinkPad T470 SSD Replacement guide.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 3 of 3
      • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
      • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
      • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
      • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
      Ask FixBot
    3. Lenovo ThinkPad T470 SSD Assembly Replacement: step 5, image 1 of 1
      • Remove the bottom cover from the laptop.
      • Disconnect the battery from the board before continuing.
      Ask FixBot
    1. Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: step 6, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: step 6, image 2 of 2
      • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T470 SSD Assembly Replacement: step 7, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to separate the connector from its socket.
      Ask FixBot
    3. Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 3 of 3
      • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
      Ask FixBot
3 other people completed this guide.
Kristen Gismondi
109,535 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 123
All Time: 2,860
