Up to 20% off select tools
Lenovo ThinkPad T470 RAM Replacement
Views: 16K
View statistics:
Past 24 Hours:
11
Past 7 Days:
70
Past 30 Days:
310
All Time:
16,118
Comments: 6
6 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the RAM in your Lenovo ThinkPad T470.
RAM (short for “random access memory”) provides temporary storage for a computer. RAM enables a computer to run with optimal speed and performance. Some signs of faulty RAM include the blue screen of death, sluggish performance, or random crashes and reboots.
This laptop is equipped with two RAM slots and a maximum RAM capacity of 32 GB. You can run a RAM diagnostic tool to see if replacement is needed.
Before beginning this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    1. Lenovo ThinkPad T470 RAM Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T470 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 RAM Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T470 RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad T470 RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad T470 RAM Replacement: step 4, image 3 of 3
      • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
      • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
      • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
      • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
      Ask FixBot
    3. Lenovo ThinkPad T470 RAM Replacement: step 5, image 1 of 1
      • Remove the bottom cover from the laptop.
      • Disconnect the battery from the board before continuing.
      Ask FixBot
    1. Lenovo ThinkPad T470 RAM Replacement, RAM: step 6, image 1 of 3 Lenovo ThinkPad T470 RAM Replacement, RAM: step 6, image 2 of 3 Lenovo ThinkPad T470 RAM Replacement, RAM: step 6, image 3 of 3
      • Use your fingers to flip the black flap covering the top stick of RAM down.
      Ask FixBot
    2. Lenovo ThinkPad T470 RAM Replacement: step 7, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement: step 7, image 2 of 2
      • Use your fingers to push the metal clips on either end of the RAM outwards.
      • The RAM will pop up by a few millimeters.
      Ask FixBot
    3. Lenovo ThinkPad T470 RAM Replacement: step 8, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement: step 8, image 2 of 2
      • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
      Ask FixBot
    4. Lenovo ThinkPad T470 RAM Replacement: step 9, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement: step 9, image 2 of 2
      • Use your fingers to flip the black flap covering the bottom stick of RAM up.
      • Use your thumbs to push the metal clips on either end of the RAM outwards.
      Ask FixBot
    5. Lenovo ThinkPad T470 RAM Replacement: step 10, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement: step 10, image 2 of 2
      • The RAM will pop up slightly.
      Ask FixBot
    6. Lenovo ThinkPad T470 RAM Replacement: step 11, image 1 of 2 Lenovo ThinkPad T470 RAM Replacement: step 11, image 2 of 2
      Ask FixBot
6 other people completed this guide.
Author
with
Kristen Gismondi
110,409 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 70
Past 30 Days: 310
All Time: 16,118
