Lenovo ThinkPad T470 Motherboard Replacement
    1. Lenovo ThinkPad T470 Motherboard Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T470 Motherboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T470 Motherboard Replacement, Internal Components: step 3, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement, Internal Components: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T470 Motherboard Replacement: step 4, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 4, image 2 of 2
      • Place the laptop so that the top is facing upwards.
      • Open the lid of the laptop.
      Ask FixBot
    3. Lenovo ThinkPad T470 Motherboard Replacement: step 5, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 5, image 2 of 2
      • Place your fingers on the bottom edge of the keyboard.
      • Use a small amount of pressure to push the keyboard towards the screen.
      Ask FixBot
    4. Lenovo ThinkPad T470 Motherboard Replacement: step 6, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 6, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 6, image 3 of 3
      • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
      • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
      Ask FixBot
    5. Lenovo ThinkPad T470 Motherboard Replacement: step 7, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
      Ask FixBot
    6. Lenovo ThinkPad T470 Motherboard Replacement: step 8, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 8, image 2 of 2
      • Use your hands to lift the keyboard up and away from the laptop.
      Ask FixBot
    7. Lenovo ThinkPad T470 Motherboard Replacement: step 9, image 1 of 1
      • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
      Ask FixBot
    8. Lenovo ThinkPad T470 Motherboard Replacement: step 10, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 10, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 10, image 3 of 3
      • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
      • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
      • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
      • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
      Ask FixBot
    9. Lenovo ThinkPad T470 Motherboard Replacement: step 11, image 1 of 1
      • Remove the bottom cover from the laptop.
      Ask FixBot
    10. Lenovo ThinkPad T470 Motherboard Replacement: step 12, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 12, image 2 of 2
      • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
      Ask FixBot
    11. Lenovo ThinkPad T470 Motherboard Replacement: step 13, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 13, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 13, image 3 of 3
      • Use your hands to lift the battery up and away from the laptop.
      Ask FixBot
    12. Lenovo ThinkPad T470 Motherboard Replacement: step 14, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 14, image 2 of 2
      • Use your fingers to flip the black flap covering the top stick of RAM down.
      Ask FixBot
    13. Lenovo ThinkPad T470 Motherboard Replacement: step 15, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 15, image 2 of 2
      • Use your thumbs to push the metal clips on either end of the RAM outwards.
      • The RAM will pop up by a few millimeters.
      Ask FixBot
    14. Lenovo ThinkPad T470 Motherboard Replacement: step 16, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 16, image 2 of 2
      • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
      Ask FixBot
    15. Lenovo ThinkPad T470 Motherboard Replacement: step 17, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 17, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 17, image 3 of 3
      • Use your fingers to flip the black flap covering the bottom stick of RAM up.
      Ask FixBot
    16. Lenovo ThinkPad T470 Motherboard Replacement: step 18, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 18, image 2 of 2
      Ask FixBot
    17. Lenovo ThinkPad T470 Motherboard Replacement: step 19, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 19, image 2 of 2
      • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
      Ask FixBot
    18. Lenovo ThinkPad T470 Motherboard Replacement: step 20, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 20, image 2 of 2
      • Use the flat end of a spudger to separate the connector from its socket.
      Ask FixBot
    19. Lenovo ThinkPad T470 Motherboard Replacement: step 21, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 21, image 2 of 2
      • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
      Ask FixBot
    20. Lenovo ThinkPad T470 Motherboard Replacement: step 22, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 22, image 2 of 2
      • Use a finger to press the black flap covering the Wi-Fi card down.
      Ask FixBot
    21. Lenovo ThinkPad T470 Motherboard Replacement: step 23, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 23, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 23, image 3 of 3
      • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
      • When reassembling, reattach the gray wire on the left and the black wire on the right.
      Ask FixBot
    22. Lenovo ThinkPad T470 Motherboard Replacement: step 24, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 24, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
      Ask FixBot
    23. Lenovo ThinkPad T470 Motherboard Replacement: step 25, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 25, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 25, image 3 of 3
      • Use your fingers to lift the Wi-Fi card up and out of its slot.
      • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
      Ask FixBot
    24. Lenovo ThinkPad T470 Motherboard Replacement: step 26, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 26, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
      Ask FixBot
    25. Lenovo ThinkPad T470 Motherboard Replacement: step 27, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 27, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 27, image 3 of 3
      • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
      Ask FixBot
    26. Lenovo ThinkPad T470 Motherboard Replacement: step 28, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 28, image 2 of 2
      • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
      Ask FixBot
    27. Lenovo ThinkPad T470 Motherboard Replacement: step 29, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
      • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
      Ask FixBot
    28. Lenovo ThinkPad T470 Motherboard Replacement: step 30, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 30, image 2 of 2
      • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
      • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
      Ask FixBot
    1. Lenovo ThinkPad T470 Motherboard Replacement, Motherboard: step 31, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement, Motherboard: step 31, image 2 of 2
      • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T470 Motherboard Replacement: step 32, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 32, image 2 of 2
      • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T470 Motherboard Replacement: step 33, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 33, image 2 of 2
      • Use the flat end of a spudger to flip the power button cable's black tab up.
      Ask FixBot
    4. Lenovo ThinkPad T470 Motherboard Replacement: step 34, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 34, image 2 of 2
      • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
      Ask FixBot
    5. Lenovo ThinkPad T470 Motherboard Replacement: step 35, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 35, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 35, image 3 of 3
      • Use your fingers to detach the red and blue antenna cables from their slots.
      Ask FixBot
    6. Lenovo ThinkPad T470 Motherboard Replacement: step 36, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 36, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
      Ask FixBot
    7. Lenovo ThinkPad T470 Motherboard Replacement: step 37, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 37, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 37, image 3 of 3
      • Use your fingers to lift the USB bracket up and away from the laptop.
      Ask FixBot
    8. Lenovo ThinkPad T470 Motherboard Replacement: step 38, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 38, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
      Ask FixBot
    9. Lenovo ThinkPad T470 Motherboard Replacement: step 39, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 39, image 2 of 2
      • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
      Ask FixBot
    10. Lenovo ThinkPad T470 Motherboard Replacement: step 40, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 40, image 2 of 2
      • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
      Ask FixBot
    11. Lenovo ThinkPad T470 Motherboard Replacement: step 41, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 41, image 2 of 2
      • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
      Ask FixBot
    12. Lenovo ThinkPad T470 Motherboard Replacement: step 42, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
      Ask FixBot
    13. Lenovo ThinkPad T470 Motherboard Replacement: step 43, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 43, image 2 of 2
      • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
      Ask FixBot
    14. Lenovo ThinkPad T470 Motherboard Replacement: step 44, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 44, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
      Ask FixBot
    15. Lenovo ThinkPad T470 Motherboard Replacement: step 45, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 45, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 45, image 3 of 3
      • Use your fingers to slide the I/O bracket to the left.
      • Lift the I/O bracket up and away from the laptop.
      Ask FixBot
    16. Lenovo ThinkPad T470 Motherboard Replacement: step 46, image 1 of 2 Lenovo ThinkPad T470 Motherboard Replacement: step 46, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
      • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
      Ask FixBot
    17. Lenovo ThinkPad T470 Motherboard Replacement: step 47, image 1 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 47, image 2 of 3 Lenovo ThinkPad T470 Motherboard Replacement: step 47, image 3 of 3
      • Use both hands to lift the motherboard up and away from the laptop.
      Ask FixBot
4 other people completed this guide.
Kristen Gismondi
108,491 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,413 Guides authored
1 Guide Comment
Well don’t forget to run your Maintenance Utility to add back your S/N, Machine Type, and Model Number that Lenovo deletes just because they want you to go to an authorized service center.
fivestarnet - Reply Share
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 117
All Time: 9,216
