Lenovo ThinkPad T470 Fingerprint Reader Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
127
All Time:
4,497
Comments: 5
5 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove the fingerprint reader from a Lenovo ThinkPad T470 laptop.
The fingerprint reader allows you to log into a laptop installed with Windows 10 by scanning your unique fingerprint. The fingerprint reader may be faulty if you notice error messages and an inability to log in when attempting to use the fingerprint reader. This issue may not require a replacement, so be sure to visit Lenovo’s troubleshooting manual for the fingerprint reader.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Parts
Tools
    1. Lenovo ThinkPad T470 Fingerprint Reader Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T470 Fingerprint Reader Replacement, Internal Components: step 3, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement, Internal Components: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 4, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 4, image 2 of 2
      • Place the laptop so that the top is facing upwards.
      • Open the lid of the laptop.
      Ask FixBot
    3. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 5, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 5, image 2 of 2
      • Place your fingers on the bottom edge of the keyboard.
      • Use a small amount of pressure to push the keyboard towards the screen.
      Ask FixBot
    4. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 6, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 6, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 6, image 3 of 3
      • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
      • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
      Ask FixBot
    5. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 7, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
      Ask FixBot
    6. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 8, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 8, image 2 of 2
      • Use your hands to lift the keyboard up and away from the laptop.
      Ask FixBot
    7. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 9, image 1 of 1
      • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
      Ask FixBot
    8. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 10, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 10, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 10, image 3 of 3
      • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
      • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
      • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
      • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
      Ask FixBot
    9. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 11, image 1 of 1
      • Remove the bottom cover from the laptop.
      Ask FixBot
    10. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 12, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 12, image 2 of 2
      • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
      Ask FixBot
    11. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 13, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 13, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 13, image 3 of 3
      • Use your hands to lift the battery up and away from the laptop.
      Ask FixBot
    12. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 14, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 14, image 2 of 2
      • Use your fingers to flip the black flap covering the top stick of RAM down.
      Ask FixBot
    13. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 15, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 15, image 2 of 2
      • Use your thumbs to push the metal clips on either end of the RAM outwards.
      • The RAM will pop up by a few millimeters.
      Ask FixBot
    14. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 16, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 16, image 2 of 2
      • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
      Ask FixBot
    15. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 17, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 17, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 17, image 3 of 3
      • Use your fingers to flip the black flap covering the bottom stick of RAM up.
      Ask FixBot
    16. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 18, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 18, image 2 of 2
      Ask FixBot
    17. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 19, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 19, image 2 of 2
      • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
      Ask FixBot
    18. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 20, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 20, image 2 of 2
      • Use the flat end of a spudger to separate the connector from its socket.
      Ask FixBot
    19. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 21, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 21, image 2 of 2
      • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
      Ask FixBot
    20. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 22, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 22, image 2 of 2
      • Use a finger to press the black flap covering the Wi-Fi card down.
      Ask FixBot
    21. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 23, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 23, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 23, image 3 of 3
      • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
      • When reassembling, reattach the gray wire on the left and the black wire on the right.
      Ask FixBot
    22. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 24, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 24, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
      Ask FixBot
    23. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 25, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 25, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 25, image 3 of 3
      • Use your fingers to lift the Wi-Fi card up and out of its slot.
      • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
      Ask FixBot
    24. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 26, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 26, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
      Ask FixBot
    25. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 27, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 27, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 27, image 3 of 3
      • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
      Ask FixBot
    26. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 28, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 28, image 2 of 2
      • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
      Ask FixBot
    27. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 29, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
      • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
      Ask FixBot
    28. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 30, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 30, image 2 of 2
      • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
      • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
      Ask FixBot
    1. Lenovo ThinkPad T470 Fingerprint Reader Replacement, Motherboard: step 31, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement, Motherboard: step 31, image 2 of 2
      • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 32, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 32, image 2 of 2
      • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 33, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 33, image 2 of 2
      • Use the flat end of a spudger to flip the power button cable's black tab up.
      Ask FixBot
    4. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 34, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 34, image 2 of 2
      • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
      Ask FixBot
    5. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 35, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 35, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 35, image 3 of 3
      • Use your fingers to detach the red and blue antenna cables from their slots.
      Ask FixBot
    6. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 36, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 36, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
      Ask FixBot
    7. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 37, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 37, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 37, image 3 of 3
      • Use your fingers to lift the USB bracket up and away from the laptop.
      Ask FixBot
    8. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 38, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 38, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
      Ask FixBot
    9. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 39, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 39, image 2 of 2
      • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
      Ask FixBot
    10. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 40, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 40, image 2 of 2
      • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
      Ask FixBot
    11. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 41, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 41, image 2 of 2
      • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
      Ask FixBot
    12. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 42, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
      Ask FixBot
    13. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 43, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 43, image 2 of 2
      • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
      Ask FixBot
    14. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 44, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 44, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
      Ask FixBot
    15. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 45, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 45, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 45, image 3 of 3
      • Use your fingers to slide the I/O bracket to the left.
      • Lift the I/O bracket up and away from the laptop.
      Ask FixBot
    16. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 46, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 46, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
      • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
      Ask FixBot
    17. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 47, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 47, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 47, image 3 of 3
      • Use both hands to lift the motherboard up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T470 Fingerprint Reader Replacement, Fingerprint Reader: step 48, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement, Fingerprint Reader: step 48, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the fingerprint reader bracket.
      Ask FixBot
    2. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 49, image 1 of 2 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 49, image 2 of 2
      • Peel up the white ribbon cable.
      • Potential for device damage: The cable may be attached to the laptop with strong adhesive, so be cautious not to tear it.
      Ask FixBot
    3. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 50, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 50, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 50, image 3 of 3
      • Use the flat end of a spudger to pry the metal bracket away from the fingerprint reader.
      • Use your fingers to lift the bracket up and away from the fingerprint reader.
      Ask FixBot
    4. Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 51, image 1 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 51, image 2 of 3 Lenovo ThinkPad T470 Fingerprint Reader Replacement: step 51, image 3 of 3
      • Use the flat end of a spudger to pry the fingerprint reader up and away from the laptop.
      Ask FixBot
3 other people completed this guide.
Kristen Gismondi
109,546 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 127
All Time: 4,497
