Lenovo ThinkPad T470 External Battery Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
141
All Time:
5,848
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the external battery on your Lenovo ThinkPad T470.
A healthy laptop battery will keep your laptop powered on, even when your device is unplugged from an external power source.
If your laptop no longer holds a charge, or loses its charge very quickly, you most likely have a dead or failing battery which may require replacement. Depending on the cause of your faulty battery, you may be able to resolve the issue using this list of troubleshooting symptoms and solutions from Lenovo’s support forum.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
    1. Lenovo ThinkPad T470 External Battery Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 External Battery Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 External Battery Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T470 External Battery Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 External Battery Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 External Battery Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 other people completed this guide.
Kristen Gismondi
109,541 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 141
All Time: 5,848
