Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement
    1. Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Battery: step 1, image 3 of 3
      • Ensure the computer is shut down by depressing the power button above the keyboard.
      • Slide each of the two battery locking tabs toward the closest edge.
      • Remove the battery.
      • Reinstall the new battery by simply pushing it into the battery compartment; you do not need to hold the two retaining tabs back.
      Ask FixBot
    1. Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Wi-Fi/Bluetooth Module: step 2, image 1 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Wi-Fi/Bluetooth Module: step 2, image 2 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement, Wi-Fi/Bluetooth Module: step 2, image 3 of 3
      • Loosen the eight 4 mm-long captive Phillips screws securing the lower case.
      • Insert an opening pick into the seam between the lower case and chassis.
      • Pry around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    2. Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement: step 3, image 1 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement: step 3, image 2 of 3 Lenovo ThinkPad T460p Wi-Fi/Bluetooth Module Replacement: step 3, image 3 of 3
      • Use the pointed end of a spudger to lift and disconnect the two coaxial connectors.
      • Note the location of the specifically colored wires; they can be mixed up easily in reassembly.
      • Remove the 4 mm-long screw securing the card.
      • Remove the module.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 73
All Time: 191
