Lenovo ThinkPad T460 Power Button Board Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
127
All Time:
3,017
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the power button board in your Lenovo ThinkPad T460.
The power button board contains the button that turns on the computer when pressed. Diagnosing a faulty power button may be tricky since some of the symptoms are similar to a faulty battery or AC adapter. If you are pressing the power button but your laptop is not turning on, take a look at this Lenovo ThinkPad troubleshooting manual before attempting a power button board replacement.
If you need to perform a replacement, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Tools
    1. Lenovo ThinkPad T460 Power Button Board Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement, External Battery: step 1, image 3 of 3
      • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
      • Place the laptop so that the bottom is facing upwards.
      • Slide the latch on the left side of the battery to the left until it clicks in place.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 2, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 2, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 2, image 3 of 3
      • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
      • Use your other hand to slide the battery towards the back of the laptop.
      • Lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T460 Power Button Board Replacement, Keyboard: step 3, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement, Keyboard: step 3, image 2 of 2
      • Use the pointed end of a spudger to pry the two rubber stoppers out of the battery compartment.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 4, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 4, image 2 of 2
      • Place the laptop so that the top is facing upwards.
      • Open the lid of the laptop.
      Ask FixBot
    3. Lenovo ThinkPad T460 Power Button Board Replacement: step 5, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 5, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 5, image 3 of 3
      • Use the pointed end of a spudger to push the keyboard towards the screen using the two notches on the bottom of the keyboard.
      Ask FixBot
    4. Lenovo ThinkPad T460 Power Button Board Replacement: step 6, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 6, image 2 of 2
      • Loosen the six captive screws in the keyboard frame using a Phillips #0 screwdriver.
      • These screws are hard to see. Make sure you have pushed the keyboard towards the screen as far as it will go to see the screws better.
      Ask FixBot
    5. Lenovo ThinkPad T460 Power Button Board Replacement: step 7, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 7, image 2 of 2
      • Use your hands to pull the keyboard up and towards you by a few millimeters to remove it from its tray.
      • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when lifting it.
      Ask FixBot
    6. Lenovo ThinkPad T460 Power Button Board Replacement: step 8, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 8, image 2 of 2
      • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
      • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
      Ask FixBot
    7. Lenovo ThinkPad T460 Power Button Board Replacement: step 9, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of blunt-nosed tweezers to lift the black flap away from the cable connectors.
      Ask FixBot
    8. Lenovo ThinkPad T460 Power Button Board Replacement: step 10, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 10, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flap securing the ribbon cable.
      Ask FixBot
    9. Lenovo ThinkPad T460 Power Button Board Replacement: step 11, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 11, image 2 of 2
      • Use a pair of blunt-nosed tweezers to pull the ribbon cable out of its connector.
      Ask FixBot
    10. Lenovo ThinkPad T460 Power Button Board Replacement: step 12, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 12, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flap securing the bottom ribbon cable.
      Ask FixBot
    11. Lenovo ThinkPad T460 Power Button Board Replacement: step 13, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 13, image 2 of 2
      Ask FixBot
    12. Lenovo ThinkPad T460 Power Button Board Replacement: step 14, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 14, image 2 of 2
      • Pull the ribbon cables through the slot in the black flap.
      • Remove the black flap from the keyboard.
      Ask FixBot
    13. Lenovo ThinkPad T460 Power Button Board Replacement: step 15, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 15, image 2 of 2
      • Use your hands to lift the keyboard up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T460 Power Button Board Replacement, Bottom Cover: step 16, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement, Bottom Cover: step 16, image 2 of 2
      • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 17, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 17, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 17, image 3 of 3
      • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
      • Pry the lower left corner of the bottom cover up by a few millimeters.
      • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
      • You may hear some snapping noises as the clips are released.
      Ask FixBot
    3. Lenovo ThinkPad T460 Power Button Board Replacement: step 18, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 18, image 2 of 2
      • Slide the spudger along the right and top sides of the bottom cover to release the clips.
      • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
      Ask FixBot
    4. Lenovo ThinkPad T460 Power Button Board Replacement: step 19, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 19, image 2 of 2
      • Use the spudger to pry the upper left corner up by a few millimeters.
      • Pry up the sections of the bottom cover with printed logos of the ports.
      • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
      Ask FixBot
    5. Lenovo ThinkPad T460 Power Button Board Replacement: step 20, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 20, image 2 of 2
      • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
      Ask FixBot
    6. Lenovo ThinkPad T460 Power Button Board Replacement: step 21, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 21, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 21, image 3 of 3
      • Use both hands to lift the bottom cover up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T460 Power Button Board Replacement, Internal Battery: step 22, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement, Internal Battery: step 22, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to pull the black connector out of its socket.
      • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 23, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 23, image 2 of 2
      • Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
      Ask FixBot
    3. Lenovo ThinkPad T460 Power Button Board Replacement: step 24, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 24, image 2 of 2
      • Use your hands to lift the battery up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T460 Power Button Board Replacement, Motherboard: step 25, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement, Motherboard: step 25, image 2 of 2
      • Remove the single 3.7 mm screw from the left side of the hard drive using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 26, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 26, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 26, image 3 of 3
      • Use your hand to lift up the hard drive by a few millimeters.
      • Pull the hard drive to the left to detach it from its connector and remove it from the laptop.
      Ask FixBot
    3. Lenovo ThinkPad T460 Power Button Board Replacement: step 27, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 27, image 2 of 2
      • Use your fingers to lift up the black flap covering the RAM.
      Ask FixBot
    4. Lenovo ThinkPad T460 Power Button Board Replacement: step 28, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 28, image 2 of 2
      • Use your fingers to push the metal clips on either end of the first RAM stick outwards.
      • The RAM stick will pop up by a few millimeters.
      Ask FixBot
    5. Lenovo ThinkPad T460 Power Button Board Replacement: step 29, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 29, image 2 of 2
      • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
      Ask FixBot
    6. Lenovo ThinkPad T460 Power Button Board Replacement: step 30, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 30, image 2 of 2
      • Use your fingers to push the metal clips on either end of the second RAM stick outwards.
      Ask FixBot
    7. Lenovo ThinkPad T460 Power Button Board Replacement: step 31, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 31, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 31, image 3 of 3
      Ask FixBot
    8. Lenovo ThinkPad T460 Power Button Board Replacement: step 32, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 32, image 2 of 2
      • Use your fingers to lift up the black flap covering the Wi-Fi card.
      Ask FixBot
    9. Lenovo ThinkPad T460 Power Button Board Replacement: step 33, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 33, image 2 of 2
      • Use the flat end of a spudger to disconnect the gray and black coaxial wires from the Wi-Fi card.
      • When reassembling, reattach the gray wire on the top and the black wire on the bottom.
      Ask FixBot
    10. Lenovo ThinkPad T460 Power Button Board Replacement: step 34, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 34, image 2 of 2
      • Remove the single 3.7 mm screw from the right side of the Wi-Fi card using a Phillips #1 screwdriver.
      Ask FixBot
    11. Lenovo ThinkPad T460 Power Button Board Replacement: step 35, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 35, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 35, image 3 of 3
      • Use your fingers to lift the Wi-Fi card up and out of its slot.
      • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 32-35 to remove it.
      Ask FixBot
    12. Lenovo ThinkPad T460 Power Button Board Replacement: step 36, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 36, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to pull the white CMOS battery connector out of its socket.
      Ask FixBot
    13. Lenovo ThinkPad T460 Power Button Board Replacement: step 37, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 37, image 2 of 2
      • Use your fingers to pull the red and black bundled wire from its slot.
      Ask FixBot
    14. Lenovo ThinkPad T460 Power Button Board Replacement: step 38, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 38, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 38, image 3 of 3
      • Pry the CMOS battery up using the flat end of a spudger.
      • You may need to loosen the adhesive underneath the battery with the spudger before the battery can be removed.
      Ask FixBot
    15. Lenovo ThinkPad T460 Power Button Board Replacement: step 39, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 39, image 2 of 2
      • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
      Ask FixBot
    16. Lenovo ThinkPad T460 Power Button Board Replacement: step 40, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 40, image 2 of 2
      • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan assembly in a crosswise pattern.
      • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan assembly in a crosswise pattern.
      • Secure the screws using the same cross-pattern when reassembling the fan.
      Ask FixBot
    17. Lenovo ThinkPad T460 Power Button Board Replacement: step 41, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 41, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 41, image 3 of 3
      • Use your hands to lift the fan assembly up and away from the laptop.
      Ask FixBot
    18. Lenovo ThinkPad T460 Power Button Board Replacement: step 42, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to detach the USB cable from the motherboard.
      Ask FixBot
    19. Lenovo ThinkPad T460 Power Button Board Replacement: step 43, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 43, image 2 of 2
      • Use your fingers to move the detached part of the USB cable away from the motherboard.
      Ask FixBot
    20. Lenovo ThinkPad T460 Power Button Board Replacement: step 44, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 44, image 2 of 2
      • Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
      Ask FixBot
    21. Lenovo ThinkPad T460 Power Button Board Replacement: step 45, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 45, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 45, image 3 of 3
      • Use a pair of tweezers to lift the LCD cable bracket away from the motherboard.
      Ask FixBot
    22. Lenovo ThinkPad T460 Power Button Board Replacement: step 46, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 46, image 2 of 2
      • Use the flat end of a spudger to disconnect the flat-topped LCD cable connector.
      Ask FixBot
    23. Lenovo ThinkPad T460 Power Button Board Replacement: step 47, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 47, image 2 of 2
      • Use the pointed end of a spudger to lift up the metal bracket on the camera/microphone cable.
      Ask FixBot
    24. Lenovo ThinkPad T460 Power Button Board Replacement: step 48, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 48, image 2 of 2
      • Use the flat end of a spudger to detach the camera/microphone cable connector from its socket.
      Ask FixBot
    25. Lenovo ThinkPad T460 Power Button Board Replacement: step 49, image 1 of 1
      • Use your fingers to remove the gray and red coaxial cables from their slots along the motherboard.
      Ask FixBot
    26. Lenovo ThinkPad T460 Power Button Board Replacement: step 50, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 50, image 2 of 2
      • Use your fingers to remove the blue and black coaxial cables from their slots along the top of the motherboard.
      Ask FixBot
    27. Lenovo ThinkPad T460 Power Button Board Replacement: step 51, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 51, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flap securing the power button cable.
      Ask FixBot
    28. Lenovo ThinkPad T460 Power Button Board Replacement: step 52, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 52, image 2 of 2
      • Use a pair of blunt nose tweezers to slide the power button cable out of its connector on the motherboard.
      Ask FixBot
    29. Lenovo ThinkPad T460 Power Button Board Replacement: step 53, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 53, image 2 of 2
      • Use a pair of blunt nose tweezers to pull the white speaker cable out of its socket on the motherboard.
      Ask FixBot
    30. Lenovo ThinkPad T460 Power Button Board Replacement: step 54, image 1 of 1
      • This laptop does not have a fingerprint reader.
      • If your laptop has a fingerprint reader, use the flat end of a spudger to lift up the black tab and slide the cable out of its socket on the motherboard.
      Ask FixBot
    31. Lenovo ThinkPad T460 Power Button Board Replacement: step 55, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 55, image 2 of 2
      • Use the flat end of a spudger to flip up the locking flap securing the trackpad ribbon cable.
      Ask FixBot
    32. Lenovo ThinkPad T460 Power Button Board Replacement: step 56, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 56, image 2 of 2
      Ask FixBot
    33. Lenovo ThinkPad T460 Power Button Board Replacement: step 57, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 57, image 2 of 2
      • Use the flat end of a spudger to disconnect the smart card cable from the motherboard.
      Ask FixBot
    34. Lenovo ThinkPad T460 Power Button Board Replacement: step 58, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 58, image 2 of 2
      • Use a pair of blunt nose tweezers to pull the white DC-in cable out of its socket on the motherboard.
      Ask FixBot
    35. Lenovo ThinkPad T460 Power Button Board Replacement: step 59, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 59, image 2 of 2
      • Remove the six 3.7 mm screws from the motherboard using a Phillips #1 screwdriver.
      Ask FixBot
    36. Lenovo ThinkPad T460 Power Button Board Replacement: step 60, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 60, image 2 of 2
      • Remove the single 5.6 mm screw from the Ethernet/USB port bracket using a Phillips #1 screwdriver.
      Ask FixBot
    37. Lenovo ThinkPad T460 Power Button Board Replacement: step 61, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 61, image 2 of 2
      • Use your fingers to slide the bracket to the left and away from the motherboard.
      Ask FixBot
    38. Lenovo ThinkPad T460 Power Button Board Replacement: step 62, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 62, image 2 of 2
      • Use both hands to pull the motherboard straight up and away from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad T460 Power Button Board Replacement, Power Button Board: step 63, image 1 of 1
      • Remove two 4.7 mm screws from the hinge in the upper left corner using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T460 Power Button Board Replacement: step 64, image 1 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 64, image 2 of 3 Lenovo ThinkPad T460 Power Button Board Replacement: step 64, image 3 of 3
      • Lift the bottom of the laptop up by a few inches to rotate the hinge in the upper left corner.
      • Place the bottom of the laptop back down.
      Ask FixBot
    3. Lenovo ThinkPad T460 Power Button Board Replacement: step 65, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 65, image 2 of 2
      • Use your fingers to peel the power button board ribbon cable away from the laptop.
      Ask FixBot
    4. Lenovo ThinkPad T460 Power Button Board Replacement: step 66, image 1 of 2 Lenovo ThinkPad T460 Power Button Board Replacement: step 66, image 2 of 2
      • Use your fingers to lift the power button board up and away from the laptop.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Kristen Gismondi
109,564 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 127
All Time: 3,017
