Lenovo ThinkPad T431S Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
54
All Time:
764
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to locate and replace the Lenovo T431s fan. The cooling fan is what keeps your processing unit cool so the elements of your computer don’t overheat. If you are experiencing malfunction, overheat warning messages, or hot components, you might need to replace your cooling fan.
Tools
    1. Lenovo ThinkPad T431S Fan Replacement, Fan: step 1, image 1 of 2 Lenovo ThinkPad T431S Fan Replacement, Fan: step 1, image 2 of 2
      • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
      • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
      • Carefully pry off the back panel using the opening tool.
      Ask FixBot
    2. Lenovo ThinkPad T431S Fan Replacement: step 2, image 1 of 2 Lenovo ThinkPad T431S Fan Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
      Ask FixBot
    3. Lenovo ThinkPad T431S Fan Replacement: step 3, image 1 of 3 Lenovo ThinkPad T431S Fan Replacement: step 3, image 2 of 3 Lenovo ThinkPad T431S Fan Replacement: step 3, image 3 of 3
      • Disconnect the cable attached to the fan, pulling the connector straight down.
      • Lift and remove the fan.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 54
All Time: 764
