Lenovo ThinkPad T430s CMOS Battery Replacement
    1. Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: step 1, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: step 1, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: step 1, image 3 of 3
      • Flip your ThinkPad over so the back faces up.
      • With the Phillips #0 screwdriver, remove the seven 5 mm screws on the outer edge of the case.
      • Remove the two 7 mm screws in the upper corners of the case.
      • Remove the five 5 mm screws in the battery compartment.
      Ask FixBot
    2. Lenovo ThinkPad T430s CMOS Battery Replacement: step 2, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 2, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 2, image 3 of 3
      • In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
      • Remove the 3 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
      • Pull out the Wi-Fi card.
      • Remove the 6 mm and 3 mm screws in the RAM stick compartment.
      Ask FixBot
    3. Lenovo ThinkPad T430s CMOS Battery Replacement: step 3, image 1 of 1
      • Remove the 5 mm and 3 mm screws in the hard drive compartment.
      Ask FixBot
    4. Lenovo ThinkPad T430s CMOS Battery Replacement: step 4, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 4, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 4, image 3 of 3
      • Flip the ThinkPad right side up and open the lid.
      • Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
      • Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
      • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
      • Set the keyboard aside.
      Ask FixBot
    5. Lenovo ThinkPad T430s CMOS Battery Replacement: step 5, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 5, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 5, image 3 of 3
      • Remove the two 5 mm screws from the case covering the disk drive.
      • Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
      • Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
      • Lift the palm rest up from the motherboard.
      Ask FixBot
    6. Lenovo ThinkPad T430s CMOS Battery Replacement: step 6, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 6, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 6, image 3 of 3
      • Pull the red, blue, and white wires in the left corner away from the motherboard.
      • Peel the snap securing the ribbon with the pointy end of the spudger.
      • Pull the ribbon back towards you.
      Ask FixBot
    7. Lenovo ThinkPad T430s CMOS Battery Replacement: step 7, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 7, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 7, image 3 of 3
      • Rotate the ThinkPad so the back side faces you.
      • With the Phillips #1 screwdriver, unscrew the two 7 mm screws from the corners.
      • Lift the screen and pull it out of the hinges. Set the screen down behind the rest of the ThinkPad.
      Ask FixBot
    8. Lenovo ThinkPad T430s CMOS Battery Replacement: step 8, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 8, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 8, image 3 of 3
      • With the pointy end of the spudger, lift the plastic snap holding down the SN4 LVDS cable. Pull the cable out of the clasp towards you.
      • Pry the SN4 LED cable out of where it connects to the motherboard.
      • Set the display aside.
      Ask FixBot
    9. Lenovo ThinkPad T430s CMOS Battery Replacement: step 9, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 9, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 9, image 3 of 3
      • With the pointy end of the spudger, lift the plastic snap securing the ribbon at the front of the ThinkPad.
      • Pull the ribbon out of the clasp towards you.
      Ask FixBot
    10. Lenovo ThinkPad T430s CMOS Battery Replacement: step 10, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 10, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 10, image 3 of 3
      • Unscrew the 9 mm screw, five 5 mm screws, and four 3 mm screws on the motherboard using a Phillips #0 screwdriver.
      • When you remove the screws, the small motherboard stick in the top right corner will pop out of the case. Pull it out.
      • Lift the motherboard out of the case.
      Ask FixBot
    11. Lenovo ThinkPad T430s CMOS Battery Replacement: step 11, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 11, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement: step 11, image 3 of 3
      • Flip the motherboard over so the back faces up.
      • Loosen the four screws securing the heat sink to the motherboard. The silver metal rectangle on the front of the motherboard will fall off. Set it aside.
      • Lift the fan and heat sink away from the motherboard.
      Ask FixBot
    1. Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: step 12, image 1 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: step 12, image 2 of 3 Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: step 12, image 3 of 3
      • Flip the motherboard over and disconnect the CMOS battery from the motherboard by pulling the cable away from the connector.
      • It is important to note that the cable must be pulled evenly away from the connector to prevent damage to the connector or cable.
      Ask FixBot
    2. Lenovo ThinkPad T430s CMOS Battery Replacement: step 13, image 1 of 2 Lenovo ThinkPad T430s CMOS Battery Replacement: step 13, image 2 of 2
      • Use a nylon spudger to slightly push against the white bundled cable connector while evenly pulling the cable from the other side.
      • Remove the CMOS battery from the motherboard.
      Ask FixBot
6 Guide Comments
Why is it necessary to continue after Step 4 where the cmos battery already appears to be accessible?
Piko Faj - Reply Share
yes this is correct
Nathan Reeves - Reply Share
Holy Crap! It's right under that square door right in the middle on the back! You only have to remove two screws!
Rex Dwyer - Reply Share
exactly! sort of an odd guide
They went over the top with the instructions. All you have to do is take out the keyboard.
Luis Donado - Reply Share
Past 24 Hours: 14
Past 7 Days: 56
Past 30 Days: 264
All Time: 8,371
