Lenovo ThinkPad T400s LCD Screen Replacement
    1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
      Ask FixBot
    2. Lenovo ThinkPad T400s LCD Screen Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
      • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
      Ask FixBot
    3. Lenovo ThinkPad T400s LCD Screen Replacement: step 3, image 1 of 2 Lenovo ThinkPad T400s LCD Screen Replacement: step 3, image 2 of 2
      • Remove the LCD connector by pulling on the ribbon cable at the connection.
      Ask FixBot
    4. Lenovo ThinkPad T400s LCD Screen Replacement: step 4, image 1 of 1
      • Lift the LCD screen out to replace.
      • Make sure to remove the screen with both hands and from opposite edges of the screen.
      Ask FixBot
7 other people completed this guide.
Christopher Noone
235 Reputation
1 Guide authored
Cal Poly, Team 6-18, Maness Spring 2015 Member of Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 113
All Time: 3,420
