Introduction
Follow this guide to replace the trackpad (aka ClickPad) in your Lenovo ThinkPad T16 Gen 3 laptop.
Lenovo sometimes refers to this part as a "ClickPad," and several vendors (i.e. Chicony, Sunrex, Transimage) produce their own variants. Keep this in mind when purchasing a replacement.
You may need a replacement "sponge" for your new trackpad. Lenovo's part number for this is 5M21L98590. Use the original trackpad as a reference for sponge position.
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
Pry up the base cover until the clips unfasten.
Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
Lift and remove the base cover.
Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
Lift the edge of the battery with the connector to disconnect it.
Remove the battery
Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
Lower the battery into place so the connector goes over its socket.
Use your fingernail or the flat end of a spudger to flip up the locking flap on the NFC cable ZIF connector (labeled "JNFC1").
Use your fingers or tweezers to gently pull the cable by its plastic pull tab out of its socket.
Use the flat end of a spudger to lift the trackpad cable press connector straight up and out of its socket on the NFC reader board.
Use your fingernail or the flat end of a spudger to flip up the locking flap on the trackpad cable ZIF connector (labeled "JCP1").
Use tweezers or your fingers to gently pull the cable by its plastic pull tab out of its socket.
Use a Phillips screwdriver to remove the seven 2.5 mm‑long screws securing the trackpad to the frame.
Use your fingers to slightly lift the trackpad by its edges near the motherboard and slide the opposite edge out from its recess.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it. If a replacement sponge is required, use the original trackpad as a reference for application.
