Lenovo ThinkPad T16 Gen 3 RAM Replacement
    1. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Prepare your laptop for disassembly: step 1, image 2 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Prepare your laptop for disassembly: step 1, image 3 of 3
      • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
      • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
      • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
      Ask FixBot
    2. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Loosen the base cover screws: step 2, image 1 of 2 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Loosen the base cover screws: step 2, image 2 of 2
      • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
      Ask FixBot
    3. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Pry up the base cover: step 3, image 1 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Pry up the base cover: step 3, image 2 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Pry up the base cover: step 3, image 3 of 3
      • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
      • Pry up the base cover until the clips unfasten.
      Ask FixBot
    4. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the base cover: step 4, image 1 of 2 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the base cover: step 4, image 2 of 2
      • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
      • Lift and remove the base cover.
      • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
      Ask FixBot
    1. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Loosen the battery screws: step 5, image 1 of 2 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Loosen the battery screws: step 5, image 2 of 2
      • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
      • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
      Ask FixBot
    2. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the battery: step 6, image 1 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the battery: step 6, image 2 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the battery: step 6, image 3 of 3
      • Lift the edge of the battery with the connector to disconnect it.
      • You may feel a little resistance from the battery connector as it disconnects—that's normal.
      • Remove the battery
      • During reassembly:
      • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
      • Lower the battery into place so the connector goes over its socket.
      Ask FixBot
    1. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the RAM shield: step 7, image 1 of 2 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the RAM shield: step 7, image 2 of 2
      • Grab the pull tab in the middle of the RAM shield and pull straight up to remove it from its clips.
      • Since the RAM shield is thin, it may bend slightly during removal. During reassembly, lay the shield into place and press down firmly around the perimeter to engage all the clips.
      Ask FixBot
    2. Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the RAM: step 8, image 1 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the RAM: step 8, image 2 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement, Remove the RAM: step 8, image 3 of 3
      • Use your fingers to simultaneously push the two metal tabs on the edges of the RAM module down and outwards to unlatch them—the RAM should pop up at a slight angle.
      • Remove the RAM module.
      Ask FixBot
    3. Lenovo ThinkPad T16 Gen 3 RAM Replacement: step 9, image 1 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement: step 9, image 2 of 3 Lenovo ThinkPad T16 Gen 3 RAM Replacement: step 9, image 3 of 3
      • Repeat the process for the other RAM module.
      • During reassembly, fully insert the RAM at the angle it popped up at, then press down to engage the metal arms.
      Ask FixBot
Nick Schultz
67,325 Reputation
355 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
1 Guide Comment
Be sure to follow the procedure for disabling the built-in battery prior to opening the laptop.
Valamir - Reply Share
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 156
All Time: 2,238
