Introduction
Follow this guide to remove and replace the fan in your Lenovo ThinkPad T14 Gen 7 laptop.
For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
Repeat at the top-left corner.
Use your fingers to squeeze the two latches on either side of the battery connector.
While squeezing the latches, lift the top edge of the battery up.
Use tweezers or your fingernails to gently push the fan connector out of its socket to disconnect it.
