Lenovo ThinkPad T14 Gen 3 SSD Replacement
    1. Lenovo ThinkPad T14 Gen 3 SSD Replacement, Back Panel: step 1, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the seven captive screws securing the back panel.
      • The screws are captive and will not come out of the panel.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 2, image 1 of 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 2, image 2 of 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the back panel and chassis.
      • Slide the opening pick around the perimeter of the device to release the clips that hold the back panel to the device.
      • Remove the back panel.
      Ask FixBot
    1. Lenovo ThinkPad T14 Gen 3 SSD Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement, Battery: step 3, image 2 of 2
      • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
      • There is a risk to your laptop if the battery is not discharged properly.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 4, image 3 of 3
      • Slide the battery from the battery connector and remove it.
      Ask FixBot
    1. Lenovo ThinkPad T14 Gen 3 SSD Replacement, SSD - Hard Drive: step 5, image 1 of 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement, SSD - Hard Drive: step 5, image 2 of 2
      • Use a JIS #1 screwdriver to remove the single screw securing the SSD. As seen circled here opposite of the connector.
      • Put the screw somewhere safe to use for the replacement SSD.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 6, image 1 of 2 Lenovo ThinkPad T14 Gen 3 SSD Replacement: step 6, image 2 of 2
      • Place your fingers on either side of the card near the port, and gently pull it straight out.
      • Be careful not to use too much pressure or bend the card
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 88
Past 30 Days: 403
All Time: 4,372
