Lenovo ThinkPad T14 Gen 3 RAM Replacement
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Back Panel: step 1, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the seven captive screws securing the back panel.
      • The screws are captive and will not come out of the panel.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the back panel and chassis.
      • Slide the opening pick around the perimeter of the device to release the clips that hold the back panel to the device.
      • Remove the back panel.
      Ask FixBot
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: step 3, image 2 of 2
      • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
      • There is a risk to your laptop if the battery is not discharged properly.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 4, image 3 of 3
      • Slide the battery from the battery connector and remove it.
      Ask FixBot
    1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, RAM (Random Access Memory): step 5, image 1 of 1
      • Lift the plastic covering the RAM stick.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 6, image 1 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 6, image 2 of 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 6, image 3 of 3
      • This device is missing the RAM.
      • If you do have one gently pull the metal clips on each side to disengage the clips holding the card.
      Ask FixBot
    3. Lenovo ThinkPad T14 Gen 3 RAM Replacement: step 7, image 1 of 1
      • Slide the old RAM from the slot.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
1 Guide Comment
Only applicable to Intel, AMD uses soldered LPDDR5 RAM.
Jacob Langseth - Reply Share
Past 24 Hours: 14
Past 7 Days: 115
Past 30 Days: 512
All Time: 5,106
