Lenovo ThinkPad T14 Gen 3 Keyboard Replacement
    1. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 1 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 2 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 3 of 3
      • Start by disabling the internal battery in the BIOS.
      • You can enable the battery again by connecting the included power adapter.
      • If you choose to skip this step, make sure that the laptop is fully powered off before you start to avoid damaging anything.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Loosen the keyboard screws: step 2, image 1 of 1
      • Loosen the two screws holding the keyboard in place.
      • Note: These are captive screws that don't come out fully.
      Ask FixBot
    3. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Slide keyboard up: step 3, image 1 of 1
      • Slide the keyboard up until the tabs at the bottom are free.
      • Try not to press any of the keys or it will be difficult to slide.
      Ask FixBot
    4. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 3 of 3
      • Lift the bottom slightly and pull out from the frame.
      • Note: Be mindful of the fragile cables that are still attached.
      • Once you have it out, fold it down on the frame.
      Ask FixBot
    5. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disconnect the keyboard cables: step 5, image 1 of 1
      • Using a spudger or your fingernail, carefully disconnect the two cables connecting the keyboard to the motherboard.
      Ask FixBot
11 other people completed this guide.
Zachariah Orton
549 Reputation
1 Guide authored
1 Guide Comment
Danke
nun braucht man auch kein spezialwerkzeug mehr wie bei den alten T14
Thanks
now you don't need any special tools like with the old T14
Ingo Schneider - Reply Share
Past 24 Hours: 22
Past 7 Days: 108
Past 30 Days: 451
All Time: 16,796
