Introduction
Whenever a repair is done to the internals of a device, or for cleaning, the cover will need to be removed. You may also need this guide if the bottom panel is damaged and need to replace it. This guide will help you remove the back panel of your Lenovo Thinkpad T14 Gen 3 to access the internals of the machine.
Before you begin this repair, power off and unplug your laptop.
Use a Phillips #1 screwdriver to loosen the seven captive screws securing the back panel.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
