Lenovo ThinkPad T14 Gen 1 RAM Replacement
    1. Lenovo ThinkPad T14 Gen 1 RAM Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement, Lower Case: step 1, image 3 of 3
      • Turn off your laptop completely before starting the disassembly process.
      • Use a Phillips #1 screwdriver to loosen the following captive screws:
      • The top two 6.8 mm corner screws
      • Four 5.8 mm-long screws
      • The screws will remain in the case when fully loosened.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to pry the bottom panel.
      • Insert the end of the opening tool into the seam between the bottom and top cover.
      • Slide the opening tool around the edge of the bottom panel to release the clips holding them together.
      • The popping sounds during this process is normal.
      • Gently remove the bottom panel.
      • Using too much force can break the plastic clips securing the bottom panel.
      Ask FixBot
    1. Lenovo ThinkPad T14 Gen 1 RAM Replacement, RAM: step 3, image 1 of 2 Lenovo ThinkPad T14 Gen 1 RAM Replacement, RAM: step 3, image 2 of 2
      • Lift the black flap to reveal the RAM slot.
      Ask FixBot
    2. Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 1 RAM Replacement: step 4, image 3 of 3
      • Using both thumbs gently push the two latches on either side of the slot apart to free the RAM.
      • Slide the RAM stick out from the slot on the motherboard.
      • When inserting a new RAM stick, align the notch on the RAM with the notch in the slot. When it is securely inserted, press down to click it into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 29
Past 7 Days: 134
Past 30 Days: 547
All Time: 3,286
