Introduction
This guide shows how to replace the battery in a Lenovo ThinkPad T14 Gen 1. The battery supplies power to the laptop, and replacement may be necessary if it can no longer hold a charge.
Before you begin, completely power off the computer and disconnect the charging adapter and any external peripherals. Work on a clean, uncluttered surface to reduce the risk of damage or injury while handling internal components.
Use a Phillips #1 screwdriver to loosen the following captive screws:
The top two 6.8 mm corner screws
Four 5.8 mm-long screws
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
3 other people completed this guide.
