Lenovo ThinkPad P51s SSD Replacement
  1. Lenovo ThinkPad P51s SSD Replacement, SSD: step 1, image 1 of 2 Lenovo ThinkPad P51s SSD Replacement, SSD: step 1, image 2 of 2
    • Flip the laptop so the bottom is facing up.
    • Place it on a soft cloth so you don’t scratch the lid.
    Ask FixBot
  2. Lenovo ThinkPad P51s SSD Replacement: step 2, image 1 of 3 Lenovo ThinkPad P51s SSD Replacement: step 2, image 2 of 3 Lenovo ThinkPad P51s SSD Replacement: step 2, image 3 of 3
    • Slide both locking latches outward using your thumbs.
    • Keep the right latch held in the unlocked position with your right thumb. With your left hand, push the battery out of the slot.
    • Once it detaches, use both hands to slide the battery out.
    Ask FixBot
  3. Lenovo ThinkPad P51s SSD Replacement: step 3, image 1 of 2 Lenovo ThinkPad P51s SSD Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to loosen all seven captive screws that secure the lower case.
    • Do not try to remove the captive screws. They should remain in the bottom case.
    Ask FixBot
  4. Lenovo ThinkPad P51s SSD Replacement: step 4, image 1 of 3 Lenovo ThinkPad P51s SSD Replacement: step 4, image 2 of 3 Lenovo ThinkPad P51s SSD Replacement: step 4, image 3 of 3
    • Insert a iFixit Opening Tool into the gap along one edge of the laptop.
    • Gently slide it around the perimeter to release the clips.
    • Work slowly and avoid twisting the tool to prevent cracking the cover or bending the frame.
    • Once all the clips are released, lift the cover off.
    • Metal tools can crack the plastic clips—use only plastic prying tools
    Ask FixBot
  5. Lenovo ThinkPad P51s SSD Replacement: step 5, image 1 of 1
    • The SSD is located next to the internal battery.
    Ask FixBot
  6. Lenovo ThinkPad P51s SSD Replacement: step 6, image 1 of 3 Lenovo ThinkPad P51s SSD Replacement: step 6, image 2 of 3 Lenovo ThinkPad P51s SSD Replacement: step 6, image 3 of 3
    • Press the plastic pull-tab inward toward the drive to release the locking mechanism.
    • Pull the tab outwards to slide the SSD and its caddy out.
    • Disconnect the SATA cable by pulling it straight out from the connector.
    • Do not pull on the cable wires themselves. Only pull from the connector to avoid damage.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 51
All Time: 352
