Introduction
The ThinkPad P51s uses Lenovo’s dual “PowerBridge” battery system, which includes a removable external battery and an internal backup battery mounted inside the chassis. Over time, the internal battery can degrade, leading to symptoms such as rapid power drain, sudden shutdowns when unplugged, failure to charge past a certain percentage, or the laptop not powering on unless the charger is plugged in. Replacing the internal battery restores normal power delivery and increases overall runtime.
Before beginning this repair, shut down the laptop completely and disconnect the AC adapter. Lenovo recommends removing the external battery first to isolate power from the board. Because lithium-ion cells can hold charge even when disconnected, avoid puncturing, bending, or applying pressure to the battery during removal. If the battery is swollen or leaking, stop immediately and follow safe disposal procedures instead of continuing the repair.
This guide will walk you step-by-step through safely accessing and replacing the internal battery using standard tools. Take your time when opening the bottom cover, as some clips and ribbon cables are located near the edges.
For optimal performance, calibrate your newly installed battery after completing this guide.
