Lenovo ThinkPad P50s RAM Replacement
    1. Lenovo ThinkPad P50s RAM Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad P50s RAM Replacement, Battery: step 1, image 2 of 2
      • Flip the device over so the bottom is facing you.
      Ask FixBot
    2. Lenovo ThinkPad P50s RAM Replacement: step 2, image 1 of 2 Lenovo ThinkPad P50s RAM Replacement: step 2, image 2 of 2
      • Use your thumb to slide the right lock switch button outward.
      Ask FixBot
    3. Lenovo ThinkPad P50s RAM Replacement: step 3, image 1 of 3 Lenovo ThinkPad P50s RAM Replacement: step 3, image 2 of 3 Lenovo ThinkPad P50s RAM Replacement: step 3, image 3 of 3
      • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
      • When replacing the battery, make sure that the connectors are aligned properly.
      • You may hear a click when the battery is fully seated and the lock engages.
      Ask FixBot
    1. Lenovo ThinkPad P50s RAM Replacement, Base Cover: step 4, image 1 of 2 Lenovo ThinkPad P50s RAM Replacement, Base Cover: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to unscrew the eight 2 mm captive screws.
      • These screws should not be removed entirely; you will be able to take off the base cover once they are loosened.
      Ask FixBot
    2. Lenovo ThinkPad P50s RAM Replacement: step 5, image 1 of 3 Lenovo ThinkPad P50s RAM Replacement: step 5, image 2 of 3 Lenovo ThinkPad P50s RAM Replacement: step 5, image 3 of 3
      • With the plastic opening tool, pry up the base cover.
      • Slide the opening tool around the edge of the laptop to release the snap tabs.
      • You may need to use opening picks to hold the tabs apart, as the base is securely attached and tends to snap back into place.
      Ask FixBot
    3. Lenovo ThinkPad P50s RAM Replacement: step 6, image 1 of 2 Lenovo ThinkPad P50s RAM Replacement: step 6, image 2 of 2
      • Lift the base cover off the laptop.
      Ask FixBot
    1. Lenovo ThinkPad P50s RAM Replacement, RAM: step 7, image 1 of 3 Lenovo ThinkPad P50s RAM Replacement, RAM: step 7, image 2 of 3 Lenovo ThinkPad P50s RAM Replacement, RAM: step 7, image 3 of 3
      • With your thumbs, press outward on the two white retaining arms to release the RAM stick.
      • Slide the RAM out of the socket at the same angle it was released to avoid bending the connecting pins.
      • When sliding the RAM stick into the socket, carefully align the connecting pins to avoid damaging the connector or the RAM stick. Push down on the RAM until the white arms click into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Evan G
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 74
All Time: 502
