Introduction
If you notice slow performance, frequent crashes, trouble opening files, slow startup, or error messages, your hard drive may be failing and should be replaced. Fortunately, replacing a damaged SSD is often more straightforward than it seems. This guide will walk you through the essential steps to safely remove and replace your laptop M.2 SSD using simple and straightforward steps.
Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
Pull up the notch with your fingernail or a spudger.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
