Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
102
All Time:
610
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your device is no longer responding like it used to, you might need to replace the trackpad. Fortunately, replacing a damaged trackpad is often more straightforward than it seems. This guide will walk you through the essential steps to safely remove and replace your laptop trackpad using simple and straightforward steps.
Tools
    1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: step 1, image 1 of 2 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: step 1, image 2 of 2
      • Slide the battery latch to the left to unlock it and remove the battery.
      Ask FixBot
    2. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case screws: step 2, image 1 of 1
      • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
      • The screws will not come all the way out; do not attempt to remove them from the case.
      • Pull up the notch with your fingernail or a spudger.
      Ask FixBot
    3. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: step 3, image 1 of 2 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: step 3, image 2 of 2
      • Lift the lower case up and off of the chassis.
      Ask FixBot
    1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: step 4, image 1 of 2 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: step 4, image 2 of 2
      • Remove the following screws with a Phillips #00 screwdriver:
      • Seven 5.7 mm screws
      • Five 4.3 mm screws
      • Three 12.6 mm screws
      Ask FixBot
    2. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: step 5, image 1 of 2 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: step 5, image 2 of 2
      • Turn the computer over and open the lid.
      • Insert an opening pick in the seam between the keyboard bezel and chassis.
      • Pry around the entire perimeter until the keyboard assembly fully releases.
      Ask FixBot
    3. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: step 6, image 1 of 3 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: step 6, image 2 of 3 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: step 6, image 3 of 3
      • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
      • Detach the connectors that connect to the trackpad.
      • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
      • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
609 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 102
All Time: 610
