Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement
    1. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Turn off your laptop: step 1, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Turn off your laptop: step 1, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Turn off your laptop: step 1, image 3 of 3
      • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
      • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
      Ask FixBot
    2. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover screws: step 2, image 1 of 1
      • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
      Ask FixBot
    3. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's left side: step 3, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's left side: step 3, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's left side: step 3, image 3 of 3
      • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
      • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
      • Pivot the pick down and slide it around the corner to release the clips.
      Ask FixBot
    4. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 4, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 4, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 4, image 3 of 3
      • Slide the opening pick along the left edge to release the clips securing the cover.
      Ask FixBot
    5. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's right side: step 5, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's right side: step 5, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover's right side: step 5, image 3 of 3
      • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
      Ask FixBot
    6. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 6, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 6, image 2 of 2
      • Slide the opening pick along the right edge to release the clips securing the cover.
      Ask FixBot
    7. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: step 7, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: step 7, image 2 of 2
      • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
      Ask FixBot
    8. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 8, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 8, image 2 of 2
      • Lift and remove the base cover.
      Ask FixBot
    1. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the battery screws: step 9, image 1 of 1
      • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
      • Use a Phillips screwdriver to loosen the six captive screws securing the battery.
      Ask FixBot
    2. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: step 10, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: step 10, image 2 of 2
      • Grasp the top edge of the battery and lift to disconnect it.
      • You may feel a little resistance from the battery connector as it disconnects—that's normal.
      Ask FixBot
    3. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 11, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement: step 11, image 2 of 2
      • Lift and remove the battery.
      Ask FixBot
    1. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Loosen the LPCAMM2 screws: step 12, image 1 of 1
      • Use a Phillips screwdriver to loosen the three captive screws securing the LPCAMM2 bracket.
      • The loosening order doesn't matter.
      Ask FixBot
    2. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 bracket: step 13, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 bracket: step 13, image 2 of 2
      • Grab the edges of the LPCAMM2 bracket and lift straight up to remove it.
      • If your LPCAMM2 module came up with the bracket, use your fingers to gently separate it from the bracket.
      • Avoid touching the gold underside of the module—your skin oils can interfere with the electrical contacts. If you touch it by accident and plan to re-use it, clean it with high-concentration isopropyl alcohol (>90%) and a lint-free cloth before reinstalling it.
      Ask FixBot
    3. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2: step 14, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2: step 14, image 2 of 2
      • Grab the edges of the LPCAMM2 and lift straight up to remove it.
      Ask FixBot
    4. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Check the compression connector: step 15, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Check the compression connector: step 15, image 2 of 2
      • Follow this step if you've accidentally dislodged the compression connector or if you need to replace a damaged one.
      • Don't grab the compression connector by its delicate spring contacts. If they bend, the connector won't work properly.
      • Grasp the compression connector by the edges and lift straight up to remove it.
      • Avoid touching the exposed LPCAMM2 contact surface on the motherboard.
      • The compression connector is keyed to fit in only one direction. If it doesn't sit flush during reassembly, you may need to flip or rotate it to align the pegs with the holes in the board.
      Ask FixBot
    5. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Reassembly: install the LPCAMM2: step 16, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Reassembly: install the LPCAMM2: step 16, image 2 of 2
      • The remaining steps show how to reassemble the device.
      • Grip the LPCAMM2 by its edges, and lay it on top of the compression connector.
      • Make sure the LPCAMM2 aligns with the pegs.
      Ask FixBot
    6. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Install the bracket: step 17, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Install the bracket: step 17, image 2 of 2
      • Lay the bracket on top of the LPCAMM2 and align it using the screw holes.
      Ask FixBot
    7. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the LPCAMM2: step 18, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the LPCAMM2: step 18, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the LPCAMM2: step 18, image 3 of 3
      • Tighten the three LPCAMM2 screws in the order depicted on the module.
      • In this case, tighten the screws centerleftright.
      • Tighten the screws until they're snug. Don't over-tighten them, or you could damage the module.
      Ask FixBot
    8. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Reinstall the battery: step 19, image 1 of 2 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Reinstall the battery: step 19, image 2 of 2
      • Align the bottom edge of the battery to its recess.
      • Lay the battery into its recess and press down gently.
      Ask FixBot
    9. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the battery: step 20, image 1 of 1
      • Use a Phillips screwdriver to tighten the six captive screws to re-secure the battery.
      Ask FixBot
    10. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the base cover: step 21, image 1 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the base cover: step 21, image 2 of 3 Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the base cover: step 21, image 3 of 3
      • Align the base cover to the chassis and lay it in place.
      • Press firmly along the sides and corners of the base cover to reengage the clips.
      Ask FixBot
    11. Lenovo ThinkPad P1 Gen 7 LPCAMM2 Memory Replacement, Secure the base cover: step 22, image 1 of 1
      • Use a Phillips screwdriver to tighten the six captive screws to re-secure the base cover.
      Ask FixBot
7 other people completed this guide.
Arthur Shi
346,248 Reputation
921 Guides authored
iFixit Member of iFixit
Staff
123 Members
76,843 Guides authored
2 Guide Comments
Thank you, iFixit, for the detailed, easy-to-understand repair guide on the new, revolutionary LPCAMM2 memory on the ThinkPad P1 Gen 7.
Rijul Razdan - Reply Share
If notebook doesn't woкk after that, but blinks esc-f1-some elsу leds by cycle, just wait few minutes and dont turn it off, it's ok
Petr Kravtsov - Reply Share
Past 24 Hours: 16
Past 7 Days: 52
Past 30 Days: 326
All Time: 53,066
