Lenovo ThinkPad L590 Keyboard Replacement
    1. Lenovo ThinkPad L590 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Lenovo ThinkPad L590 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Shut down your ThinkPad L590 before beginning; do not put it to sleep or hibernate. Disconnect the AC adapter and any peripheral devices (USB drives, external monitors, etc.).
      • Remove the left and right click keys using an opening tool.
      Ask FixBot
    2. Lenovo ThinkPad L590 Keyboard Replacement: step 2, image 1 of 2 Lenovo ThinkPad L590 Keyboard Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the two 2.5 mm screws that were hidden under the left and right click keys.
      Ask FixBot
    3. Lenovo ThinkPad L590 Keyboard Replacement: step 3, image 1 of 2 Lenovo ThinkPad L590 Keyboard Replacement: step 3, image 2 of 2
      • Insert an opening pick in the gap between the keyboard and chassis.
      • Slide the opening pick around the perimeter of the keyboard to release all of the retaining clips.
      • Be gentle to avoid breaking the clips.
      Ask FixBot
    4. Lenovo ThinkPad L590 Keyboard Replacement: step 4, image 1 of 2 Lenovo ThinkPad L590 Keyboard Replacement: step 4, image 2 of 2
      • Gently lift the keyboard up at an angle, and tilt it back far enough to expose the ribbon cable that connects the keyboard to the motherboard.
      • Take care not to strain the ribbon cable.
      Ask FixBot
    5. Lenovo ThinkPad L590 Keyboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad L590 Keyboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad L590 Keyboard Replacement: step 5, image 3 of 3
      • Use a plastic spudger to flip up both of the ZIF locking flaps. Once the latch is released, carefully pull the ribbon cable from the motherboard.
      • Disconnect both of the ribbon cables.
      Ask FixBot
    6. Lenovo ThinkPad L590 Keyboard Replacement: step 6, image 1 of 2 Lenovo ThinkPad L590 Keyboard Replacement: step 6, image 2 of 2
      • Remove the keyboard assembly.
      Ask FixBot
German
392 Reputation
3 Guides authored
Gateway, Team 8-66, Gonzalez Fall 2024 Member of Gateway, Team 8-66, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G66
4 Members
36 Guides authored
1 Guide Comment
good guide just be aware that one of the back coove screws are hoolding in the keybord. It is in the numpad area
Martin Terje Jensen - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 125
All Time: 914
