Lenovo ThinkPad L490 Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
141
All Time:
1,787
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The internal battery of a laptop supplies power to the device when it is not receiving power from an outlet. When the battery begins to drain quickly or is damaged you will want to replace the battery of your Lenovo ThinkPad L490.
This guide will walk you through the steps to replacing the internal laptop battery of your Lenovo ThinkPad L490.
For this guide you will need the Spudger and the Phillips #0 screwdriver. This guide does not have any difficult steps other than disconnecting the connectors carefully.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo ThinkPad L490 Battery Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L490 Battery Replacement, Lower Case: step 1, image 2 of 2
      • Completely shut down your device and disconnect any peripheries before beginning.
      • Lay the laptop down with the lower case facing up.
      • Use a Phillips #00 screwdriver to remove eight 3 mm screws that secure the lower case.
      Ask FixBot
    2. Lenovo ThinkPad L490 Battery Replacement: step 2, image 1 of 2 Lenovo ThinkPad L490 Battery Replacement: step 2, image 2 of 2
      • Lift the lower case up and off of the chassis.
      • If necessary, insert an opening pick into the gap between the lower case and chassis and pry around the entire perimeter until the lower case fully releases.
      Ask FixBot
    1. Lenovo ThinkPad L490 Battery Replacement, Battery: step 3, image 1 of 1
      • Grip the battery connector and pull it directly out of its motherboard socket.
      Ask FixBot
    2. Lenovo ThinkPad L490 Battery Replacement: step 4, image 1 of 3 Lenovo ThinkPad L490 Battery Replacement: step 4, image 2 of 3 Lenovo ThinkPad L490 Battery Replacement: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three m2 x 2.5 mm screws that secure the battery.
      • Lift the battery up and out of the chassis.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Sky
85 Reputation
1 Guide authored
Gateway, Team 8-4, Gonzalez Fall 2024 Member of Gateway, Team 8-4, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 141
All Time: 1,787
