Up to 20% off select tools
Lenovo ThinkPad L470 RAM Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
131
All Time:
737
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade the memory (RAM) in a Lenovo ThinkPad L470 .
Upgrading RAM can fix sluggish performance, reduce swapping data to disk, and help with multitasking.
This procedure shows how to remove the bottom cover and swap the memory module(s).
What this part does
RAM (Random Access Memory) is the laptop’s high-speed working space for the operating system and applications.
It’s much faster than storage drives and plays a key role in overall performance.
Common symptoms of faulty/insufficient RAM
  • Random app or system crashes, freezes, or reboots
  • Failure to boot accompanied by repeated beep codes
  • Blue-screen memory errors or poor performance under heavy load
Before you begin
  • Shut down the laptop and unplug the AC adapter.
  • If upgrading, install DDR4 SO-DIMM modules that meet Lenovo ThinkPad L470 specifications.
  • If troubleshooting, try reseating the existing modules and running a memory test before replacement.
After the repair
  • Enter BIOS/Setup at startup (press F1) or open Task Manager → Performance → Memory in Windows to confirm the system recognizes the new memory capacity.
    1. Lenovo ThinkPad L470 RAM Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad L470 RAM Replacement, Battery: step 1, image 2 of 2
      • Turn off the laptop and unplug the AC adapter.
      • Slide the battery latch to unlock and lift out the external battery.
      • Hold the power button for 10 seconds to discharge any leftover power.
      Ask FixBot
    1. Lenovo ThinkPad L470 RAM Replacement, RAM: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to loosen the captive screws on the bottom cover.
      Ask FixBot
    2. Lenovo ThinkPad L470 RAM Replacement: step 3, image 1 of 1
      • Use an opening tool to pry the back cover off of the laptop.
      Ask FixBot
    3. Lenovo ThinkPad L470 RAM Replacement: step 4, image 1 of 1
      • Fold back the thin shielding flap to reveal the RAM module(s).
      Ask FixBot
    4. Lenovo ThinkPad L470 RAM Replacement: step 5, image 1 of 2 Lenovo ThinkPad L470 RAM Replacement: step 5, image 2 of 2
      • Gently push the two metal clips on the sides of the RAM outward at the same time.
      • The RAM will pop up at a 30° angle.
      Ask FixBot
    5. Lenovo ThinkPad L470 RAM Replacement: step 6, image 1 of 2 Lenovo ThinkPad L470 RAM Replacement: step 6, image 2 of 2
      • Gently pull the RAM straight out of its slot. If there are two modules, repeat the process for the second slot.
      Ask FixBot
2 other people completed this guide.
Author
with
Aiden56
210 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 131
All Time: 737
