Introduction
Go to step 1 ↓Use this guide to replace the external battery in a Lenovo ThinkPad L470. Replacing the battery can resolve power issues such as rapid drain, unexpected shutdowns, or the laptop only powering on when plugged in. A failing battery may cause the system to shut off abruptly, fail to hold a charge, or charge very slowly.
Common Symptoms of a faulty battery
- Rapid battery drain
- Laptop shuts down unexpectedly
- Battery not detected or stuck at 0-1%
- Swelling or overheating
- Laptop only turns on when plugged in
Before you begin
- Shut down Windows completely, do not use Sleep or Hibernate.
- Unplug the AC adapter.
- Turn the laptop over a clean, static-safe surface.
After the repair
- Boot into Windows and verify the battery is detected and charging.
- Update Lenovo Vantage or the BIOS if battery detection issues occur.
Turn off the laptop and unplug the AC adapter.
Slide the battery latch to unlock and lift out the external battery.
Hold the power button for 10 seconds to discharge any leftover power.
