Lenovo ThinkPad L460 LCD Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
95
All Time:
474
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A cracked or otherwise visibly broken screen will require a complete replacement of the LCD assembly. This guide will instruct you how to safely remove and replace the screen assembly on the Lenovo ThinkPad L460.
IMPORTANT:
Always ground yourself when working with sensitive electronics. Periodically touch a large metal object such as a table or chair while working or use an ESD wrist strap connected to a large metal object.
Before you begin, turn off your laptop and disconnect from the charger or any peripherals.
Tools
    1. Lenovo ThinkPad L460 LCD Assembly Replacement, Battery: step 1, image 1 of 1
      • Shut down your Lenovo ThinkPad L460 completely.
      • Disconnect the AC power adapter.
      • Disconnect all connected cables and devices.
      Ask FixBot
    2. Lenovo ThinkPad L460 LCD Assembly Replacement: step 2, image 1 of 1
      • Flip the laptop so the bottom is facing upwards.
      Ask FixBot
    3. Lenovo ThinkPad L460 LCD Assembly Replacement: step 3, image 1 of 2 Lenovo ThinkPad L460 LCD Assembly Replacement: step 3, image 2 of 2
      • Use your two thumbs to push the two locking latches to the left and the right of the battery to the unlocked position.
      • While holding the latches open, slide the battery out of the connector to remove it.
      Ask FixBot
    1. Lenovo ThinkPad L460 LCD Assembly Replacement, Back Cover: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
      • Captive screws are not meant to be removed, just loosened enough.
      • Remove the SIM tray from the side of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad L460 LCD Assembly Replacement: step 5, image 1 of 2 Lenovo ThinkPad L460 LCD Assembly Replacement: step 5, image 2 of 2
      • Use an opening tool to gently pry along the edges of the cover, releasing all the plastic clips of the laptop.
      • Carefully pull up and remove the back cover from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad L460 LCD Assembly Replacement, LCD Assembly: step 6, image 1 of 2 Lenovo ThinkPad L460 LCD Assembly Replacement, LCD Assembly: step 6, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the four 6 mm screws and a Phillips #0 screwdriver to remove the two 5 mm screws from the hinges at the corners of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad L460 LCD Assembly Replacement: step 7, image 1 of 3 Lenovo ThinkPad L460 LCD Assembly Replacement: step 7, image 2 of 3 Lenovo ThinkPad L460 LCD Assembly Replacement: step 7, image 3 of 3
      • Flip the black plastic cover up to reveal the Wi-Fi card.
      • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the coaxial cable connectors (as close to the head as possible) and lift straight up from the Wi-Fi card.
      • To make the display connector easier to access, disconnect the two white JST connectors next to it before disconnecting the display connector.
      • Use a spudger or a clean fingernail to flip up the locking flap on the display connector—this is the unlocked position.
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      Ask FixBot
    3. Lenovo ThinkPad L460 LCD Assembly Replacement: step 8, image 1 of 1
      • Carefully remove the cables from the cable guides.
      Ask FixBot
    4. Lenovo ThinkPad L460 LCD Assembly Replacement: step 9, image 1 of 2 Lenovo ThinkPad L460 LCD Assembly Replacement: step 9, image 2 of 2
      • Flip up the two hinged plates on the sides of the laptop.
      • Remove the LCD assembly from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Karl
109 Reputation
1 Guide authored
UMass Dartmouth, Team 2-4, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-4, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 95
All Time: 474
