Lenovo ThinkPad L460 Keyboard Replacement
    1. Lenovo ThinkPad L460 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Shut down your Lenovo ThinkPad L460 completely.
      • Disconnect the AC power adapter.
      • Disconnect all connected cables and devices.
      Ask FixBot
    2. Lenovo ThinkPad L460 Keyboard Replacement: step 2, image 1 of 1
      • Flip the laptop so the bottom is facing upwards.
      Ask FixBot
    3. Lenovo ThinkPad L460 Keyboard Replacement: step 3, image 1 of 2 Lenovo ThinkPad L460 Keyboard Replacement: step 3, image 2 of 2
      • Use your two thumbs to push the two locking latches to the left and the right of the battery to the unlocked position.
      • While holding the latches open, slide the battery out of the connector to remove it.
      Ask FixBot
    1. Lenovo ThinkPad L460 Keyboard Replacement, Back Cover: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
      • Captive screws are not meant to be removed, just loosened enough.
      • Remove the SIM tray from the side of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad L460 Keyboard Replacement: step 5, image 1 of 2 Lenovo ThinkPad L460 Keyboard Replacement: step 5, image 2 of 2
      • Use an opening tool to gently pry along the edges of the cover, releasing all the plastic clips of the laptop.
      • Carefully pull up and remove the back cover from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad L460 Keyboard Replacement, Keyboard: step 6, image 1 of 1
      • Flip the laptop right side up and open the cover.
      Ask FixBot
    2. Lenovo ThinkPad L460 Keyboard Replacement: step 7, image 1 of 2 Lenovo ThinkPad L460 Keyboard Replacement: step 7, image 2 of 2
      • Use a nylon spudger to press down on the small notches at the bottom of the keyboard.
      • Gently push the keyboard away from the palmrest to reveal the screws underneath.
      Ask FixBot
    3. Lenovo ThinkPad L460 Keyboard Replacement: step 8, image 1 of 2 Lenovo ThinkPad L460 Keyboard Replacement: step 8, image 2 of 2
      • Use a Phillips #00 screwdriver to loosen the keyboard screws located above the S, F, J, ;, Up Arrow, and Left Control keys.
      • They are captive screws, so they will stay in place and won’t come out.
      Ask FixBot
    4. Lenovo ThinkPad L460 Keyboard Replacement: step 9, image 1 of 3 Lenovo ThinkPad L460 Keyboard Replacement: step 9, image 2 of 3 Lenovo ThinkPad L460 Keyboard Replacement: step 9, image 3 of 3
      • Lift the keyboard from the top edge and flip it forward to expose the keyboard connector.
      • Use a nylon spudger to flip up the black locking tab.
      • Do not use a screwdriver or other metal tool, as shown in the image. Doing so can easily damage the connector or other delicate internal components.
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • Remove the keyboard from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Phoebe Gesner
159 Reputation
1 Guide authored
UMass Dartmouth, Team 2-4, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-4, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 108
All Time: 501
