Lenovo ThinkPad L460 Back Cover Replacement
    1. Lenovo ThinkPad L460 Back Cover Replacement, Battery: step 1, image 1 of 1
      • Shut down your Lenovo ThinkPad L460 completely.
      • Disconnect the AC power adapter.
      • Disconnect all connected cables and devices.
      Ask FixBot
    2. Lenovo ThinkPad L460 Back Cover Replacement: step 2, image 1 of 1
      • Flip the laptop so the bottom is facing upwards.
      Ask FixBot
    3. Lenovo ThinkPad L460 Back Cover Replacement: step 3, image 1 of 2 Lenovo ThinkPad L460 Back Cover Replacement: step 3, image 2 of 2
      • Use your two thumbs to push the two locking latches to the left and the right of the battery to the unlocked position.
      • While holding the latches open, slide the battery out of the connector to remove it.
      Ask FixBot
    1. Lenovo ThinkPad L460 Back Cover Replacement, Back Cover: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
      • Captive screws are not meant to be removed, just loosened enough.
      • Remove the SIM tray from the side of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad L460 Back Cover Replacement: step 5, image 1 of 2 Lenovo ThinkPad L460 Back Cover Replacement: step 5, image 2 of 2
      • Use an opening tool to gently pry along the edges of the cover, releasing all the plastic clips of the laptop.
      • Carefully pull up and remove the back cover from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Samuel Paintsil
531 Reputation
2 Guides authored
UMass Dartmouth, Team 2-4, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-4, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 94
All Time: 379
