Lenovo ThinkPad L440 Screen Replacement
    1. Lenovo ThinkPad L440 Screen Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad L440 Screen Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad L440 Screen Replacement, Battery: step 1, image 3 of 3
      • Open the laptop to access the power button.
      • Hold the power button in the top right until the computer powers off.
      • Turn the computer over so that the bottom of the computer is facing up
      Ask FixBot
    2. Lenovo ThinkPad L440 Screen Replacement: step 2, image 1 of 1
      • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
      Ask FixBot
    3. Lenovo ThinkPad L440 Screen Replacement: step 3, image 1 of 2 Lenovo ThinkPad L440 Screen Replacement: step 3, image 2 of 2
      • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
      Ask FixBot
    1. Lenovo ThinkPad L440 Screen Replacement, Screen: step 4, image 1 of 1
      • Use the pointed tweezers to remove the coverings on the bottom left and right of the laptop’s screen.
      Ask FixBot
    2. Lenovo ThinkPad L440 Screen Replacement: step 5, image 1 of 1
      • Remove the two black 3 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo ThinkPad L440 Screen Replacement: step 6, image 1 of 1
      • Using the plastic spudger and your fingers, pry off the plastic frame.
      Ask FixBot
    4. Lenovo ThinkPad L440 Screen Replacement: step 7, image 1 of 2 Lenovo ThinkPad L440 Screen Replacement: step 7, image 2 of 2
      • Remove the two silver 2 mm screws under the frame using a Phillips #00 screwdriver.
      Ask FixBot
    5. Lenovo ThinkPad L440 Screen Replacement: step 8, image 1 of 1
      • With the pointed tweezers, peel back the adhesive and remove the screen.
      Ask FixBot
To reassemble, follow these steps in reverse order. Turn on the laptop and test your new screen.
Catherine Miller
177 Reputation
1 Guide authored
UMass Dartmouth, Team 2-6, Konn Fall 2024 Member of UMass Dartmouth, Team 2-6, Konn Fall 2024
UMASSD-KONN-F24S2G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 82
All Time: 740
