Community-Contributed Guide
Introduction
Go to step 1 ↓This guide will take you show you how to replace the trackpad on the Lenovo ThinkPad L390. This replacement guide should be used when the trackpad is damaged. The trackpad is an essential tool for the computer, as it's used to navigate the screen. Without the trackpad, most of the functions on a computer cannot be accessed.
Tools
Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
Remove the five 4mm #00 phillips screws from the battery.
Lift the battery up with the opening tool.
To reassemble your device, follow these instructions in order.
