Lenovo ThinkPad L390 RAM Replacement
    1. Lenovo ThinkPad L390 RAM Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 RAM Replacement, Lower Case: step 1, image 2 of 2
      • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
      Ask FixBot
    2. Lenovo ThinkPad L390 RAM Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 RAM Replacement: step 2, image 2 of 2
      • Insert an opening tool in the gap between the lower case and the chassis.
      • Pry around the entire perimeter of the lower case until it fully releases.
      • Lift the lower case up and off.
      Ask FixBot
    1. Lenovo ThinkPad L390 RAM Replacement, Lenovo ThinkPad L390 Battery Disconnection: step 3, image 1 of 1
      • Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
      • Do not pull on the wires.
      Ask FixBot
    1. Lenovo ThinkPad L390 RAM Replacement, RAM: step 4, image 1 of 3 Lenovo ThinkPad L390 RAM Replacement, RAM: step 4, image 2 of 3 Lenovo ThinkPad L390 RAM Replacement, RAM: step 4, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • When released, the RAM modules will pop up at a slight angle.
      • Slide the RAM module straight out to remove it.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 113
All Time: 1,139
