Lenovo ThinkPad L390 LCD Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
40
Past 30 Days:
136
All Time:
1,172
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A working LCD screen should properly display bright, clear images and colors on screen using electrical current to control liquid crystals that control the amount of light passing through from a backlight.
If your Lenovo ThinkPad L390's LCD screen is not working you may see common symptoms such as fading colors, black spots and/or black lines appearing on the LCD screen, distorted images, or have a flickering screen. If you are experiencing these symptoms with your Lenovo ThinkPad L390, look into replacing its LCD screen using these guide steps bellow.
This guide instructs you on how to detach the LCD screen from the Lenovo ThinkPad L390. If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display.
Note:
  • Before beginning this guide, make sure to power off your laptop completely and disconnect from any external power source.
  • When following the steps of this guide keep in mind that the cover and connection cables may break if mishandled, so be cautious in order to not to damage your device.
Parts
Tools
    1. Lenovo ThinkPad L390 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Lenovo ThinkPad L390 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Lenovo ThinkPad L390 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
      • Open up the laptop lid.
      • Insert an opening pick under the bezel.
      • Slide the opening pick around the perimeter of the bezel until it fully releases.
      • Remove the bezel.
      Ask FixBot
    2. Lenovo ThinkPad L390 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the four 3 mm screws that secure the screen with a Phillips #00 screwdriver.
      • Slightly lift the screen and set it face down on top of the keyboard.
      • Take care not to strain the connected cable.
      Ask FixBot
    3. Lenovo ThinkPad L390 LCD Screen Replacement: step 3, image 1 of 3 Lenovo ThinkPad L390 LCD Screen Replacement: step 3, image 2 of 3 Lenovo ThinkPad L390 LCD Screen Replacement: step 3, image 3 of 3
      • Peel back the clear piece of tape on top of the display cable connector.
      Ask FixBot
    4. Lenovo ThinkPad L390 LCD Screen Replacement: step 4, image 1 of 2 Lenovo ThinkPad L390 LCD Screen Replacement: step 4, image 2 of 2
      • Flip up the display cable locking bar.
      Ask FixBot
    5. Lenovo ThinkPad L390 LCD Screen Replacement: step 5, image 1 of 1
      • When the bar is clear of the connector and the screen, gently disconnect the display cable connector.
      • Remove the screen.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
What is screen price
Alihasan khan - Reply Share
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 136
All Time: 1,172
