Lenovo ThinkPad L390 CMOS Battery Replacement
    1. Lenovo ThinkPad L390 CMOS Battery Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 CMOS Battery Replacement, Lower Case: step 1, image 2 of 2
      • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
      • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
      • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
      Ask FixBot
    2. Lenovo ThinkPad L390 CMOS Battery Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 CMOS Battery Replacement: step 2, image 2 of 2
      • Insert an opening tool in the gap between the lower case and the chassis.
      • Pry around the entire perimeter of the lower case until it fully releases.
      • Lift the lower case up and off.
      Ask FixBot
    1. Lenovo ThinkPad L390 CMOS Battery Replacement, CMOS Battery: step 3, image 1 of 1
      • Remove the protective tape over the CMOS battery.
      Ask FixBot
    2. Lenovo ThinkPad L390 CMOS Battery Replacement: step 4, image 1 of 1
      • Pull the white CMOS battery connector directly out of its socket.
      • Lift the battery up and off of the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 86
All Time: 1,136
