Lenovo ThinkPad Edge E420s Keyboard Replacement
    1. Lenovo ThinkPad Edge E420s Keyboard Replacement, Hard Drive: step 1, image 1 of 1
      • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
      • Flip the device over.
      Ask FixBot
    2. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
      Ask FixBot
    3. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 3, image 1 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 3, image 2 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 3, image 3 of 3
      • Swing the cover out slightly like a hinge.
      • Pull the cover directly away from the case towards the base of the laptop.
      • Lift the cover up and away from the device to remove it.
      • You may hear a slight pop when you pull the cover off.
      Ask FixBot
    4. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 4, image 1 of 1
      • Use the clear tab to slide the hard drive out of the device.
      Ask FixBot
    5. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 5, image 3 of 3
      • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
      • Slide the old hard drive directly out.
      • When reassembling, make sure the hard drive is securely in the case before beginning.
      Ask FixBot
    1. Lenovo ThinkPad Edge E420s Keyboard Replacement, Top Case: step 6, image 1 of 2 Lenovo ThinkPad Edge E420s Keyboard Replacement, Top Case: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
      • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
      Ask FixBot
    2. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 7, image 1 of 1
      • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
      Ask FixBot
    3. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 8, image 1 of 2 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 8, image 2 of 2
      • Flip over the device.
      • Open the device normally.
      Ask FixBot
    4. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 9, image 1 of 1
      • Wedge the plastic opening tool between the upper and lower halves of the lower case.
      • Lift the end of the opening tool slowly until the case separates.
      • Hearing a small popping or cracking noise during this step is normal
      Ask FixBot
    5. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 10, image 1 of 1
      • Lift the upper half of the case up slowly.
      • Be sure not to yank any of the wires connected to the case as this could damage them.
      Ask FixBot
    6. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 11, image 1 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 11, image 2 of 3 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 11, image 3 of 3
      • Locate and disconnect the 4 ribbon wires from the top case.
      • Locate and disconnect the two additional connecting wires.
      • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
      • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
      Ask FixBot
    7. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 12, image 1 of 1
      • Lift the unattached case away from the device and place it to the side.
      • When reassembling ensure that all parts of the case are properly aligned.
      Ask FixBot
    1. Lenovo ThinkPad Edge E420s Keyboard Replacement, Keyboard: step 13, image 1 of 1
      • Take the top case and turn it over so you can see the back of the keyboard.
      Ask FixBot
    2. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 14, image 1 of 1
      • Use a plastic opening tool to push out the metal spacers holding the keyboard in place.
      • After the metal spacers have been disconnected, the keyboard may simply fall out. If not, apply a small amount of pressure to pop it off.
      Ask FixBot
    3. Lenovo ThinkPad Edge E420s Keyboard Replacement: step 15, image 1 of 2 Lenovo ThinkPad Edge E420s Keyboard Replacement: step 15, image 2 of 2
      • Lift the keyboard away from the rest of the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 19
All Time: 897
