Lenovo ThinkPad E480 Ram Upgrade
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
92
All Time:
242
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Simple guide. If your device has a battery installed, disconnect it before proceeding.
  • RAM type: DDR4 SO-DIMM
  • Max supported RAM (usually 32GB for E480)
  • Number of slots: 2
Parts
Tools
      • Shut down the laptop completely, Unplug the charger, Hold the power button for ~5 seconds (to discharge remaining power)
      Ask FixBot
      • Flip the laptop over, Loosen all visible Phillips screws on the bottom cover. (They are captive screws, so they won’t come out fully)
      Ask FixBot
      • Use a plastic pry tool to carefully separate the bottom cover. Start from a corner and work your way around. Lift the cover off. Please be careful, and do not damage your precious ThinkPad.
      Ask FixBot
      • Locate the internal battery connector. Gently unplug it from the motherboard. This reduces risk of short circuits.
      Ask FixBot
      • Find the RAM modules near the center of the motherboard. You should see: One or two sticks installed, Metal retaining clips on the sides
      Ask FixBot
      • Incase you are just adding RAM, no need to remove the RAM sticks installed.
      • Remove Existing RAM (if needed) Push the metal clips outward. The RAM stick will pop up at an angle. Slide it out gently.
      Ask FixBot
      • Align the notch in the RAM stick with the slot. Insert at a slight angle (~30°) Press down until the clips snap into place. Make sure it sits flat and secure. DO NOT BREAK THE RAM STICKS.
      Ask FixBot
      • Plug the battery connector back in
      Ask FixBot
      • Place the bottom cover back on. Press around edges until it clicks. Tighten all screws.
      Ask FixBot
      • Power on the laptop. Enter BIOS (F1 on startup) or boot into Windows (Task Manager > Performance > Memory) Check that the new RAM is detected.
      Ask FixBot
Mr. luxis
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 92
All Time: 242
