Lenovo ThinkPad E15 Gen 3 RAM Replacement
    1. Lenovo ThinkPad E15 Gen 3 RAM Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad E15 Gen 3 RAM Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $5.49
      Buy
      • Loosen the eight PH1 screws on the back panel using the Phillips #1 screwdriver.
      • These screws stay seated within the back panel so do not try to remove them.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 2, image 3 of 3
      iFixit Opening Tool
      $1.99
      Buy
      • Remove back panel using a plastic opening tool or a spudger.
      • Ensure that all sides of the panel are separated (audible clicks will be heard when separating) from the device frame.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 3, image 1 of 2 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 3, image 2 of 2
      • Gently disconnect the battery from the motherboard by pulling on the fabric tab attached to the connector.
      Ask FixBot
    4. Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 4, image 3 of 3
      • Remove the battery by gently lifting the top of the battery out from the frame and then pull towards the motherboard.
      Ask FixBot
    1. Lenovo ThinkPad E15 Gen 3 RAM Replacement, RAM: step 5, image 1 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement, RAM: step 5, image 2 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement, RAM: step 5, image 3 of 3
      • Gently pull on the stainless steel shielding cover to remove it from the laptop to expose the RAM.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 6, image 1 of 2 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 6, image 2 of 2
      • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
      • The RAM will pop up from the motherboard once the tabs are spread apart.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 7, image 1 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 7, image 2 of 3 Lenovo ThinkPad E15 Gen 3 RAM Replacement: step 7, image 3 of 3
      • Slide the RAM stick from the socket to remove it from the laptop.
      • Remove it at an angle and not straight up so you don't damage the socket.
      • When installing new RAM make sure that the notch on the stick is aligned with the RAM slot on the motherboard. If the RAM's notch doesn't align with the slot, ensure that you are installing RAM that is compatible with the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 172
All Time: 1,239
