Introduction
If you're Lenovo E15 Gen 2 (Model Numbers 20T8, 20T9, 20TD, 20TE) is in need of more storage, or has a faulty drive; use this guide to swap out the Solid State Drive, which is also known as an SSD.
Note: There is a second drive slot on the motherboard which can be used to insert a second drive in the system.
Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
Pull the battery connector directly out of its socket.
Locate the SSD.
Unscrew the single 3.5 mm-long screw securing the SSD with a Philips #1 screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
