Lenovo ThinkPad E15 Gen 2 RAM Replacement
    1. Lenovo ThinkPad E15 Gen 2 RAM Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement, Lower Case: step 1, image 3 of 3
      • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
      • The screws are captive and should not have the ability to be taken out.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter until the lower case fully releases.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 3, image 1 of 1
      • Remove the lower case.
      • When reassembling, place the lower case on top of all the clips and push down around the edges until all the clips are engaged.
      Ask FixBot
    1. Lenovo ThinkPad E15 Gen 2 RAM Replacement, Lenovo ThinkPad E15 Gen 2 Battery Disconnection: step 4, image 1 of 2 Lenovo ThinkPad E15 Gen 2 RAM Replacement, Lenovo ThinkPad E15 Gen 2 Battery Disconnection: step 4, image 2 of 2
      • Pull the battery connector directly out of its socket.
      Ask FixBot
    1. Lenovo ThinkPad E15 Gen 2 RAM Replacement, RAM: step 5, image 1 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement, RAM: step 5, image 2 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement, RAM: step 5, image 3 of 3
      • Unscrew the 2.4 mm-long Phillips #1 screw securing the RAM shield.
      • Remove the shield.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 6, image 1 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 6, image 2 of 3 Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 6, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 7, image 1 of 2 Lenovo ThinkPad E15 Gen 2 RAM Replacement: step 7, image 2 of 2
      • Pull the RAM module directly out of its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Loic
277 Reputation
3 Guides authored
Texas Tech, Team 45-4, Weston Fall 2025 Member of Texas Tech, Team 45-4, Weston Fall 2025
TTU-WESTON-F25S45G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 185
All Time: 1,107
