Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement
    1. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Lower Case: step 1, image 3 of 3
      • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
      • The screws are captive and should not have the ability to be taken out.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 2, image 1 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 2, image 2 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter until the lower case fully releases.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 3, image 1 of 1
      • Remove the lower case.
      • When reassembling, place the lower case on top of all the clips and push down around the edges until all the clips are engaged.
      Ask FixBot
    1. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Lenovo ThinkPad E15 Gen 2 Battery Disconnection: step 4, image 1 of 2 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Lenovo ThinkPad E15 Gen 2 Battery Disconnection: step 4, image 2 of 2
      • Pull the battery connector directly out of its socket.
      Ask FixBot
    1. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
      • With a Phillips #1 screwdriver, remove the five 6.5 mm-long screws on the two display hinges.
      Ask FixBot
    2. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 6, image 1 of 1
      • Lift the holding latch and disconnect the display connector on the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 7, image 1 of 2 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 7, image 2 of 2
      • Locate the Wi-Fi card.
      • Disconnect the 2 antenna cables from the Wi-Fi card.
      Ask FixBot
    4. Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 8, image 1 of 2 Lenovo ThinkPad E15 Gen 2 Display Assembly Replacement: step 8, image 2 of 2
      • Remove the display assembly.
      • During reassembly, check to make sure no cables are underneath the hinges prior to putting the screen back in the hinges.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Heidy Gonzalez
255 Reputation
2 Guides authored
Texas Tech, Team 45-4, Weston Fall 2025 Member of Texas Tech, Team 45-4, Weston Fall 2025
TTU-WESTON-F25S45G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 69
All Time: 547
