Introduction
The Lenovo ThinkPad E14 Gen 4 is a 14-inch business laptop available with either 12th Gen Intel Core or AMD Ryzen 5000 Series processors, mainly marketed for professional use. Key features include fast storage up to a Gen 4 SSD, Wi-Fi 6, and a range of ports including USB-C.
This guide shows you how to replace and/or add a new solid state drive (SSD) to your Lenovo ThinkPad E14 Gen 4 laptop. Before taking your device apart, be sure that you have a compatible SSD for your device.
Never work on any device that is plugged into a power outlet. Device should be physically unplugged, not just "switched off."
SSD cards should only be removed for upgrade or repair; they are not designed for frequent handling and should be treated with care. Always back up your data before touching an SSD!
First start off by using your screwdriver to remove the screws from the back metal shield or cover. Loosen all seven captive screws on the back panel of the device with a Phillips #1 screwdriver.
