Lenovo ThinkPad A285 Screen Replacement
    1. Lenovo ThinkPad A285 Screen Replacement, Back Panel: step 1, image 1 of 3 Lenovo ThinkPad A285 Screen Replacement, Back Panel: step 1, image 2 of 3 Lenovo ThinkPad A285 Screen Replacement, Back Panel: step 1, image 3 of 3
      • Flip your laptop over so the bottom panel is facing up.
      • Use a Phillips #0 to loosen the five screws holding the back panel to the laptop.
      • These screws do not come all the way out, so loosen until free spinning.
      • Lift the bottom of the panel to separate the back panel away from the device.
      • Remove the back panel.
      Ask FixBot
    1. Lenovo ThinkPad A285 Screen Replacement, Screen: step 2, image 1 of 1
      • Use a pair of tweezers to gently disconnect the two Wi-Fi card antenna connectors.
      • Make sure to pull the connectors straight up as to not bend them.
      • Carefully unseat the cables from the retaining hooks.
      Ask FixBot
    2. Lenovo ThinkPad A285 Screen Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the six screws securing each of the hinges.
      • Lift the hinges perpendicular to the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad A285 Screen Replacement: step 4, image 1 of 2 Lenovo ThinkPad A285 Screen Replacement: step 4, image 2 of 2
      • Use a spudger to release the locking bar on each of the two connectors.
      • Disconnect both of the connectors.
      • Carefully unseat the wires from their retaining hooks to completely separate the two halves of the laptop.
      • Carefully lift the top half off of the bottom half, this may be a bit tricky but make sure to be careful every step of the way as you weave the hinges up and out of the bottom half of the laptop.
      Ask FixBot
    4. Lenovo ThinkPad A285 Screen Replacement: step 5, image 1 of 2 Lenovo ThinkPad A285 Screen Replacement: step 5, image 2 of 2
      • With the halves separated, lift the now separate screen part of the laptop up and use an opening tool to release the retaining clips that secure the screen to the bezel.
      • Slowly and carefully work your spudger around the edges of the screen, carefully forcing the two halves of the screen apart as you work your way along. There should be around 20 connectors in total for you to separate.
      Ask FixBot
    5. Lenovo ThinkPad A285 Screen Replacement: step 6, image 1 of 1
      • Release the locking bar on the connector.
      • Disconnect the connector.
      Ask FixBot
    6. Lenovo ThinkPad A285 Screen Replacement: step 7, image 1 of 1
      • Remove the screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ryder Richardson
157 Reputation
1 Guide authored
UW Tacoma, Team E-4, Rose Fall 2025 Member of UW Tacoma, Team E-4, Rose Fall 2025
UWT-ROSE-F25SEG4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 130
All Time: 458
