Lenovo ThinkBook 15 G2 ITL Fan Replacement
    1. Lenovo ThinkBook 15 G2 ITL Fan Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the computer has been shut down before proceeding.
      • Place the computer upside down on a flat surface.
      • Remove ten 5mm screws with the Phillips #00 screwdriver.
      Ask FixBot
    2. Lenovo ThinkBook 15 G2 ITL Fan Replacement: step 2, image 1 of 2 Lenovo ThinkBook 15 G2 ITL Fan Replacement: step 2, image 2 of 2
      • Pry up the latches using an opening pick.
      • Remove the lower case to show the internal components of the computer.
      Ask FixBot
    1. Lenovo ThinkBook 15 G2 ITL Fan Replacement, Fan: step 3, image 1 of 2 Lenovo ThinkBook 15 G2 ITL Fan Replacement, Fan: step 3, image 2 of 2
      • Disconnect the battery pack cable from the system board.
      • Use your fingernails to pull the connector to unplug it. Do not pull the cable.
      Ask FixBot
    2. Lenovo ThinkBook 15 G2 ITL Fan Replacement: step 4, image 1 of 3 Lenovo ThinkBook 15 G2 ITL Fan Replacement: step 4, image 2 of 3 Lenovo ThinkBook 15 G2 ITL Fan Replacement: step 4, image 3 of 3
      • Remove the two 3.5 mm screws from the fan using a Phillips #00 screwdriver.
      • Use tweezers to unplug the wiring connectors that are connected to the fan.
      • Gently remove the fan from the laptop.
      Ask FixBot
Alondra Hernandez
157 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 150
