Lenovo ThinkBook 14-IIL Battery Replacement
    1. Lenovo ThinkBook 14-IIL Battery Replacement, Back Cover: step 1, image 1 of 1
      • Remove the 5.3mm screws using your Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo ThinkBook 14-IIL Battery Replacement: step 2, image 1 of 3 Lenovo ThinkBook 14-IIL Battery Replacement: step 2, image 2 of 3 Lenovo ThinkBook 14-IIL Battery Replacement: step 2, image 3 of 3
      • Gently pry off the back of the laptop by inserting an opening pick into the crease on the sides and gently sliding while lifting the case up.
      Ask FixBot
    3. Lenovo ThinkBook 14-IIL Battery Replacement: step 3, image 1 of 1
      • Unplug the battery from the laptop carefully as to not damage the plug.
      Ask FixBot
    1. Lenovo ThinkBook 14-IIL Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the 3.8mm screws holding the battery down using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo ThinkBook 14-IIL Battery Replacement: step 5, image 1 of 3 Lenovo ThinkBook 14-IIL Battery Replacement: step 5, image 2 of 3 Lenovo ThinkBook 14-IIL Battery Replacement: step 5, image 3 of 3
      • Pull away the red and black wire out of the channel next to the battery.
      • Do not pull the cord too hard, but just enough to get it out of the way.
      Ask FixBot
    3. Lenovo ThinkBook 14-IIL Battery Replacement: step 6, image 1 of 1
      • Remove the battery from the laptop by lifting it up and out of the frame.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 102
All Time: 360
