Introduction
Go to step 1 ↓This guide will show you how to replace your Lenovo ThinkBook 13s-IML SSD.
SSDs are crucial to a computer's memory and storage. If you have a bad SSD, your computer can have slow performance, crash, and even file corruption, which can lead to a loss of data. Learning to replace it is important if you want to keep your computer functional.
Tools
Spudger4.9
Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
Insert an opening tool into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Remove the four 4 mm-long Phillips #00 screws securing the battery.
Use a spudger to push the battery connector out of its socket.
Remove the battery from the computer by pulling it up and out.
Use a Phillips #00 screwdriver to remove the 5.4 mm-long screw securing the SSD.
Pull the SSD directly out of its socket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
