Lenovo ThinkBook 13S-IML RAM Replacement
    1. Lenovo ThinkBook 13S-IML RAM Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkBook 13S-IML RAM Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkBook 13S-IML RAM Replacement, Lower Case: step 1, image 3 of 3
      • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML RAM Replacement, Battery: step 2, image 1 of 3 Lenovo ThinkBook 13S-IML RAM Replacement, Battery: step 2, image 2 of 3 Lenovo ThinkBook 13S-IML RAM Replacement, Battery: step 2, image 3 of 3
      • Caution: Make sure that your battery is discharged below 25% capacity.
      • Remove the four 4 mm-long Phillips #00 screws securing the battery.
      • Use a spudger to push the battery connector out of its socket.
      • Caution: This may take a while. Be careful, and do not try and push with much force.
      • Remove the battery from the computer by pulling it up and out.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML RAM Replacement, RAM: step 3, image 1 of 2 Lenovo ThinkBook 13S-IML RAM Replacement, RAM: step 3, image 2 of 2
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Slide the RAM module out of its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
26,156 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 69
All Time: 209
